- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NV+ V2 Volume expansion failed with 4x4TB WD red drives
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm trying to set up with 4 x 4TB Segate disks. Factory reset done, disk control ok.. but volume ends up 8TB. Latest firmware installed, all looks good.
I tried just use 3x4TB, volume ended up 7.2TB then..
I used to have 3.3TB and 12TB before.
Anyone have a solution or suggestion how to fix this? As said, diskt test ok, shows up as 4TB.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: NV+ V2 Volume expansion failed with 4x4TB WD red drives
The NAS reports volume size in TiB, not TB.
Your 3x4TB would have given you an 8 TB volume (reported as 7.2 TiB). So that one gave you the correct result. But 8 TiB for 4x4TB xraid is definitely wrong. It should have given you a 12 TB volume, with the NAS reporting the size as ~10.9 TiB.
Are you sure the volume is completely synced? It's possible that the size is slowing growing as the resync proceeds.
Also, did you do the factory reset with all disks in place?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Atm i have 3x4TB +1x3TB syncing up, so far it report 8TB but still some hours sync. I wonder why it always sync at last drive.. So when done sync it will add the TB from last drive to the 8TB.. Even i have 3x4TB + 1x3TB = 15TB minus safty 🙂
This time i didnt choose the xraid, dont remember name, but i use the nr 2 option. Read somwhere here that xraid was max 8tb and that somone choosed the other option and got 12TB..
Will tell tomorrow when sync is done.. Really hoping to get 12TB out of this nv+ v2 😄
- Mark as New
- Bookmark
- Subscribe
- Permalink
The raid i'm testin now with 3x4TB + 1x3TB is Flex-Raid Raid 5. Will that end in 8TB also? If so, why?
:)Thanks for assist so far.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sync finished.. volume total 8.1TB with 3x4TB + 1x3TB.. Flex Raid 5..
Really annoying. Did i buy those 4TB for nothing? I had same with 3x3TB and 1x4TB..
I have online backup, so i wonder. If i do raid 0, will i then get full value?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The rule for XRAID single redundancy is "sum the disks and subtract the largest". So that should give you 11 TB (reported as 10 TiB in the web ui). For XRAID to use the 3 TB drive, it needs to be installed before the first 4 TB drive (or be installed when you do the factory reset).
Also, you probably need to reboot the NAS to trigger the vertical expansion from 9 TB to 11 TB.
AFAIK, flexraid on the v2 platform doesn't handle unequal size disks, so it will give you classic RAID-5 (9 TB volume, reported as ~8.1 TiB).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Nice Calkulator. That made me see whats going on 🙂 So all is ok.. it's just the raids that dont handle different volumes.
Will go for 4x4TB then, try get most out of it with raid 5
Thanks for help 😄
