- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NV+ frontview corrupted
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: NV+ frontview corrupted
It sounds like the OS partition might be damaged. If you need the files on the NAS, you should back them up before proceeding.
Telnet connections are only accepted if the system was booted in tech support mode. Otherwise it will refuse telnet connections. You need to use ssh (for instance, putty in a Windows system). You'd log in as root, using the NAS admin password. (This assumes that ssh was enabled on the NAS).
Though if you have a backup of the data, the simplest thing to do is a factory reset, rebuild the NAS and restore the data from the backup.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's all backed up so no problem there.
- Mark as New
- Bookmark
- Subscribe
- Permalink
See pages 23-24 here: http://www.downloads.netgear.com/files/GDC/RND2110/Duov1_NV+v1_HW_en_06Dec11.pdf
The username is root, the password is infr8ntdebug
To mount the operating system (assuming xraid) you
# start_raid.sh
# mount /dev/hdc1 /sysroot
# mount --bind /proc /sysroot/proc
# mount --bind /dev /sysroot/dev
# mount --bind /dev/pts /sysroot/dev/pts
# chroot /sysroot /bin/bash
If you need to mount the data volume (read-only) :
# vgscan # vgchange -a y
# mount -o ro /dev/c/c /c
- Mark as New
- Bookmark
- Subscribe
- Permalink
See....
https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/unable-to-login-to-the-admin-page-R...
I found the ReadyDLNA log at 1.9GB in "/var/cache/minidlna/" and deleted it. The box is just a backup target to my main box. In future I would like to disable this if that is possible, as I don't use it. Or have written instruction on how to make the changes myself for future reference. I'm comfortable using the command line having had some exposure to Unix in my very deep past!
Deleting that 1.9GB file hasn't got frontview back. But at least it has requested an ip address.
ssh doesn't seem to be enabled. So at some point I must have reinstalled the software!
Anyway, it seems that a factory reset may be in order, but that will leave me with the those databases getting large again when I turn the box on every few months or so. I've written some notes on how I got this far, I just need the next steps. So could someone fill me in on those, please.
Any other thoughts?
- Mark as New
- Bookmark
- Subscribe
- Permalink
There is a add-on provided by a Netgear developer that will move the cache to the C volume: http://www.readynas.com/download/addons/4.1/Toggle_ReadyDLNA_CacheDir_1.0.bin
Note this is a "toggle" add on. There is no UI, and the install is silent. You remove it by installing it again (hence the name "toggle").
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
All is good.
Thank you StephenB.
