× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
No Volume
emma_brad2000
No Volume
Readynas Drive is showing no Volume and now i'm unable to access my data.
RN104 – ReadyNAS 100 Series 4- Bay
Is there a recovery method?
Message 1 of 12
Guru
Re: No Volume
  1. No volume?  Or an inactive volume?
  2. Have you downloaded the log zip file?
  3. Do you have any idea of what might have caused this (disk failure, unexpected power cut, forcible shutdown of the NAS, etc)?
Message 2 of 12
emma_brad2000
Re: No Volume
Disk failure, i tried to replace the failed disk and then it was showing no volume.
disk 1 is the new disk, i've tried different options but unable to see any shares.
Message 3 of 12
Guru
Re: No Volume
It is actually showing an inactive volume (at the top of the page).
  1. Looks like the failed disk was disk 2 - is that correct?
  2. Was the volume showing a degraded status when you replaced the disk?
  3. Also, did you hot-swap the disk, or do something else?
Message 4 of 12
emma_brad2000
Re: No Volume
Disk 1, yes degraded status, hot swap
But I think my efforts to repair have to helped.
Can I recreated the Raid? The 4 drives were running in Raid5. Have I lost everything?
Message 5 of 12
Guru
Re: No Volume
Maybe.  FWIW, RAID (while convenient) isn't enough to keep data safe, you need a solid backup plan to do that.
Thanks.  Try powering down the NAS, and removing disk 1.  Then power up, and see if you still see the inactive volume (or if the degraded volume comes back).
If it does come back, then I suggest backing up data (at least the critical files) before proceeding any further.
Message 6 of 12
emma_brad2000
Re: No Volume
I haven't had any luck with that but I'll try again.
any other suggestions?
Didn't work
Message 7 of 12
Guru
Re: No Volume
Have you ever used the linux command line (CLI)?
Message 8 of 12
emma_brad2000
Re: No Volume
nope
Do you know how this one was resolved?
Message 9 of 12
Guru
Re: No Volume
Probably with the linux command line interface - either remotely by Netgear support, or by the individual.  One risk there is that a mistake in entering a command can result in making the data unrecoverable.  Another is that there is no guide on diagnosing exactly what happened, and a misdiagnosis can also result in taking steps that inadvertently make recovery more difficult.
Another option is to find a way to connect the disks to a Windows PC, and use RAID recovery software that supports BTRFS .  ReclaiMe is one package that folks have used with success.  That costs, as people need to purchase the software, and generally also need to get USB docks or an enclosure that to connect up the disks.
A third approach is to contact a company that does data recovery, and get the disks to them.  Which also can be expensive.
I am guessing that you have no backup, but it would be good to confirm that.
Message 10 of 12
emma_brad2000
Re: No Volume
No external backups
I'll look into data recovery options, equipment software and companies.
Message 11 of 12
Guru
Re: No Volume
Let us know how that works out.  We can walk you through the linux command line path, as long as you understand that there is a significant risk that it won't work (and other recovery methods might then not be possible).
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 1007 views
  • 0 kudos
  • 2 in conversation
Announcements
