× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Power On ReadNAS 422 and reboots...
FerociousNAS
Tutor
Hello all,
Power On my RN422 and after 30 seconds it reboots and then fully boots up. Also have a RN524 doing the same but after two reboot it fully boots up. Other then that they both work fine. I updated the firmware to 6.10.9 but no change. Checked the fan and power supply too.
Anyone else experienced this issue?
Thx.
Message 1 of 7
Guru
Re: Power On ReadNAS 422 and reboots...
Odd.  Download the log zip files, and see if you can figure out what is happening.  Maybe start by looking in dmesg.log.
Message 2 of 7
FerociousNAS
Tutor
Thank but the logs show no errors.... 🤔
Message 3 of 7
Guru
You should be seeing something in the log zip around the time of the second reboot.
FWIW, I am not seeing this behavior in my own ReadyNAS.
Message 4 of 7
FerociousNAS
Tutor
ok I got the zip log file this time.... Looked at the dmes.log. Not really sure what I'm looking for? 🤔
Message 5 of 7
Guru
How are you shutting down the NAS?
The errors in dmesg indicate that the volume is resyncing and also that the usb drive was not properly unmounted.  So I am wondering if you doing a clean shutdown when you power down the NAS.
Message 6 of 7
FerociousNAS
Tutor
Issue seems to be resolved. I replaced the dead CMOS CR2032 battery and let the HDD sync up. Unplugged the power and flushed the flee power by holding down the power button for 10 sec, plugged power brick pack in and started up w/o the multiple reboots. I will leave it unplugged for a few hrs and report back.
Thanks for the help! 🙂
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 635 views
  • 3 kudos
  • 2 in conversation
Announcements
