× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Reply
Problem mount NFS after rest factory and update firmarework (1.10.3)
ronron
Hello,
 I had updated my readyNAS. I try to share my folder via NFS.
Spoiler
root@nas2:/data/sia-node1# cat /etc/exports
"/home" *(insecure,insecure_locks,root_squash,anonuid=99,anongid=99,no_subtree_check,rw,sync)
"/data/sia-node1" 127.0.0.1(insecure,insecure_locks,no_subtree_check,crossmnt,anonuid=99,anongid=99,root_squash,ro,async)
Any NFS options do not change the /etc/export. it is RO and the hosts do not change.
Why export home ?
From time to time, windows sharing is activated, it's super strange. While I want NFS only.
Model: ReadyNAS-4200|ReadyNAS 4200
Message 1 of 3
Accepted Solutions
Sandshark
Sensei
Re: Problem mount NFS after rest factory and update firmarework (1.10.3)
In the screen dump you uploaded, you are adjusting the SMB configuration, not NFS.  If you want to change NFS options, NFS must be selected in the second row of buttons.
Message 2 of 3
All Replies
Sandshark
Sensei
Message 2 of 3
ronron
Yes I saw that, under the old OS it was indication tags.
Its tabs are a little bad
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 684 views
  • 1 kudo
  • 2 in conversation
Announcements
