× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
RN2120 Full Disc Inactive Volumes
jkucukov
HI, Its been a while since I have gone and purged my 24/7 video recordings, as I went to check on my files I couldn't access the folders on the NAS anymore, I can still log in and navigate through the OS through the IP address but all drives are shown as inactive. From the Kernel.log file this is whats shown:
Feb 21 18:35:07 nas-36-12-CE kernel: BTRFS critical (device md127): unable to find logical 13915984560128 len 4096
I had no idea that the discs become inaccessible when full, is there a way to access the drives to make space for further operation?
Thanks,
Message 1 of 8
Guru
Re: RN2120 Full Disc Inactive Volumes
They don't always, but running out of free space can result in the file system becoming corrupted.
It's not the only cause though - are you sure that the issue was a result of a full volume?
If you have a backup (or don't need the data), then the simplest path is to destroy the volume and re-create it.
If you need to offload data, you will probably need data recovery.
Message 2 of 8
jkucukov
The performance status of all 4 discs appears healthy. Is it possible to go into read only mode to take out the important files first?
Message 3 of 8
Sandshark
Sensei
By definition, you cannot delete anything when in read-only mode.  Have you even been able to boot to read-only mode?
Message 4 of 8
jkucukov
I haven't tried the boot menu yet, I was hoping to enter the read-only mode in an attempt to copy out the important files. Is it possible to get to the boot menu from the IP Admin page or do I have to physically be at the unit and go through the reset button sequence during boot up?
Message 5 of 8
Guru
Read-only mode won't repair the file system, so it won't mount the inactive Volume(s).  Therefore it won't help you offload data.
You say "Volumes" - if you were using the default X-RAID,then you'd only have one volume.  Can you clarify what RAID mode you are using, and how many volumes you had?
Message 6 of 8
jkucukov
I was afraid of that, the only way to go about taking out the important data is with some sort of data recovery software. Its a shame that the NAS itself cannot be used for data recovery in this instance. Or at least not needing to get SATA expansion ports with cables.
The 4 drives are set up as RAID 5, I do see under the Volumes tab that the X-RAID is turned on.
The message that's shown when I log in to the Admin page shows "Remove inactive volumes to use the disk. Disk #1, 2, 3, 4" is probably where I got the volumes part
Message 7 of 8
Guru
It can be.  Netgear does offer a data recovery service, but recently folks have had trouble accessing it.
There are some cases where you can forcibly mount the volume.  Seeing if that is possible would require a full analysis of the log zip file.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 842 views
  • 1 kudo
  • 3 in conversation
Announcements
