- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RN312 “stops working”
- Mark as New
- Bookmark
- Subscribe
- Permalink
So, this has happened: this week the ReadyNAS just “stops working”. I can log into the admin webpage, and everything looks perfectly fine and there are no errors or any other loud warnings.
However, at the same time, neither my Mac Mini, my MacBook, my wife’s Windows laptop, my iPad, my android tablet, nor my iPhone can see the device. It’s “working just fine“ as long as you don’t want to access any data (so what’s the point, really?).
Anyone else seen this type of behavior? This seems to have escalated about two weeks ago.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RN312 “stops working”
What firmware are you running?
Perhaps download the log zip file, and see if there are any errors related to Samba. You can send the mods ( @JohnCM_S or @Marc_V ) a private message (PM) with a downloadable link the log zip, and ask them to analyze it. Do that using the envelope icon in the upper right of the forum page. Don't post the zip publicly.
Are all these devices accessing with SMB? If not, what protocols are you using? When the problem occurs, does it always affect all devices? Or does it just affect some?
Also, on the Windows laptop - have you tried entering \\NAS-IP-ADDRESS in the file address bar when you can't "see" the NAS? Use the real IP address for the NAS of course (and be careful to use the correct slash direction). It'd be helpful to understand if this is a discovery issue, or an access issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the reply. We are using SMB (for windows) and AFS (for the Macs). I have looked at the log files and they don't show any errors that I can see, but I will upload them to the devs as you recommended.
As for the access, we are always using the IP address for connections as I haven't set up a DNS for the house that includes the NAS so that you have to know it is there to access it (security by obscurity).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok. On the Windows system, are you entering the IP address in the file explorer address bar? Or are you looking for an icon in the left pane under "network"?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Using the IP address on all systems, at all times. No Finder lookups, no Explorer lookups.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi WildfireTech,
Can you send to us the NAS system logs via PM (private message)? We will check what is causing the issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So how are you accessing the shares from the Windows PC?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Access via Windows over the SMB shares with IP address direction (i.e. M: drive is 10.0.0.xxx mapped).
So, the "same thing but different" just happened; RN321 just totally went offline, but stayed up. Couldn't connect to web admin. Shares that were mounted dropped. Couldn't connect new shares. iPhone app couldn't communicate with it. Didn't respond to power button depress. Had to pull the freaking power cord to get the unit to shut down.
Rebooted, NO Errors, NO Warnings, NO messages of any import to review. The unit just "went on holiday" with no record, save the work I lost in trying to save data to this blasted thing.
I will send the logs as directed above, but I have little doubt that there is anything that anyone will ever find since the "admin console" flags no errors.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So, the "same thing but different" just happened; RN312 just totally went offline, but stayed up. Couldn't connect to web admin. Shares that were mounted dropped. Couldn't connect new shares.
Obviously more than the web admin interface went down. I'd look for a disk issue first, so maybe look at overall disk health in disk_info.log and look for disk or btrfs errors in system.log and kernel.log.
What apps are you running?
Did you look for a full OS partition in the logs? Do this by looking in volume.log and scrolling down to the === df -h === section.
=== df -h === Filesystem Size Used Avail Use% Mounted on udev 10M 4.0K 10M 1% /dev /dev/md0 4.0G 1002M 2.8G 27% /
/dev/md0 is the OS partition, and normally it is about 25-30% full.
Perhaps enable ssh, and see if you can connect that way when the problem happens again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Apps running :
- MySql
- "Contacts and Calendars Server"
- "linux-dash"
- "phpMyAdmin"
Services "on" are:
- SMB
- AFP
- NFS
- FTP
- iTunes
- HTTP
- HTTPS
- SSH
- Antivirus
- File Search
No issues, errors, flags, or warnings in the disk_info.log
No "disk" or "brtfs" errors in the system.log
No "disk" or "brtfs" errors in the kernel.log
In volumne.log (md0 not full but is a lot fuller than you stated):
/dev/md0 4.0G 3.0G 662M 83% /
Should I look to do some disk cleanup? What would be using the root filesystem that I could purge?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Apps running :
- MySql
- "linux-dash"
- "phpMyAdmin"
In volume.log (md0 not full but is a lot fuller than you stated):
83% is quite full, and could interfere with firmware updates. Though it shouldn't cause a hang in normal operation. Still, it should be looked at.
Likely some of these apps are installed on the OS partition. If that's the case, the usual approach is to copy the folders to the data volume (generally into the existing /data/.apps folder) and replace the original folder with a soft link to the new one.
There are some other possibilities on space, so report back on the usage after you've moved the apps to the data volume.
Apps running :
- MySql
- "linux-dash"
- "phpMyAdmin"
Services "on" are:
- SMB
- AFP
- NFS
- FTP
- iTunes
- HTTP
- HTTPS
- SSH
- Antivirus
- File Search
Do you need all these services on the NAS? You probably should disable ones you aren't using (as they will take some memory resources). From a troubleshooting perspective, it is possible that the apps or maybe the services are causing or triggering the problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did some du-ing this morning, and this is what I'm finding (everythingn except /data and /var which are both mounted on the RAID)
727M /apps
6.4M /bin
4.0K /dev
11M /etc
30M /frontview
4.0K /homes
33M /lib
4.0K /lib64
4.6M /opt
32K /root
16M /run
11M /sbin
5.4M /tmp
350M /usr
With some back-of-the-napkin calculations, this is around 1.2GB. However, / has 3.1GB used.
Any ideas on why the OS is finding a 300% usage?
- Mark as New
- Bookmark
- Subscribe
- Permalink
/apps and /home are mount points to the data volume, so the information there might be misleading.
It's best to do this by remounting to OS partition as /mnt, and then analyze space there. Among other things, that lets you see data hidden under the mount points.
# mount --bind / /mnt
If you connect USB drives to the NAS, then look in /mnt/media, which can sometimes have a lot of files that shouldn't be there.
Also, the OS file system is btrfs, so there are aspects of free space that du and df won't tell you. You should also use the btrfs commands here. For instance, btrfs fi du, and btrfs fi df.
Then when done, you unmount with
# umount /mnt
- Mark as New
- Bookmark
- Subscribe
- Permalink
*sigh*. happened again. NAS responds to ping, but cannot get the admin web system up, cannot SSH, cannot SFTP to it, cannot mount any drives.
Guess it's time to restart it again and see what I can figure out.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Okay, here's the update:
Total Exclusive Set shared Filename
0.00B 0.00B 0.00B 1
0.00B 0.00B 0.00B apps
6.28MiB 0.00B 6.28MiB bin
0.00B 0.00B 0.00B boot
0.00B 0.00B 0.00B data
0.00B 0.00B 0.00B dev
6.04MiB 0.00B 6.04MiB etc
27.49MiB 0.00B 27.49MiB frontview
0.00B 0.00B 0.00B ftp_ban.tbl
0.00B 0.00B 0.00B home
30.39MiB 0.00B 30.39MiB lib
0.00B 0.00B 0.00B lib64
0.00B 0.00B 0.00B media
0.00B 0.00B 0.00B mnt
4.30MiB 0.00B 4.30MiB opt
0.00B 0.00B 0.00B proc
0.00B 0.00B 0.00B root
0.00B 0.00B 0.00B run
10.01MiB 0.00B 10.01MiB sbin
0.00B 0.00B 0.00B srv
0.00B 0.00B 0.00B sys
0.00B 0.00B 0.00B tmp
337.86MiB 0.00B 337.86MiB usr
2.02GiB 44.00KiB 2.02GiB var
Looks like var is super full. So I dug into it:
89.73MiB 21.85MiB 67.89MiB backups
191.49MiB 166.68MiB 24.81MiB cache
16.53MiB 0.00B 16.53MiB cores
1.60GiB 1.18GiB 438.04MiB lib
0.00B 0.00B 0.00B local
65.75MiB 57.74MiB 8.01MiB log
0.00B 0.00B 0.00B mail
0.00B 0.00B 0.00B netatalk
0.00B 0.00B 0.00B opt
17.68MiB 15.62MiB 2.07MiB readynasd
0.00B 0.00B 0.00B spool
0.00B 0.00B 0.00B www
and in lib I found this (looks like MySql and clamav are using almost 1.6G)
0.00B 0.00B 0.00B apache2
33.49MiB 0.00B 33.49MiB apt
472.78MiB 0.00B 472.78MiB clamav
20.00KiB 0.00B 20.00KiB connman
0.00B 0.00B 0.00B dbus
6.03MiB 0.00B 6.03MiB dpkg
0.00B 0.00B 0.00B initscripts
0.00B 0.00B 0.00B insserv
0.00B 0.00B 0.00B mdadm
0.00B 0.00B 0.00B misc
1.10GiB 0.00B 1.10GiB mysql
0.00B 0.00B 0.00B nfs
0.00B 0.00B 0.00B nut
0.00B 0.00B 0.00B pam
0.00B 0.00B 0.00B php5
0.00B 0.00B 0.00B readyNASVault.version
0.00B 0.00B 0.00B replisync
2.53MiB 0.00B 2.53MiB samba
0.00B 0.00B 0.00B snmp
120.00KiB 0.00B 120.00KiB systemd
0.00B 0.00B 0.00B ucf
0.00B 0.00B 0.00B update-rc.d
0.00B 0.00B 0.00B urandom
0.00B 0.00B 0.00B vim
I found the PID in PS:
mysql 5887 2984 1 15:38 ? 00:00:00 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --log-error=/var/log/mysql/error.log --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/run/mysqld/mysqld.sock --port=3306
I moved /var/lib/mysql to /apps/mysql_data and killed all the PIDs and restarted MySql.
MySql seems to be working, and disk usage is down to 40% (from 83%).
- Mark as New
- Bookmark
- Subscribe
- Permalink
@WildfireTech wrote:1.10GiB 0.00B 1.10GiB mysql
I'm glad you found it. Unfortunately many apps do put stuff directly into the OS partition (even though they aren't supposed to).
