Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RN314 - Disable log/warning for the 0RPM fan speed?
- Mark as New
- Bookmark
- Subscribe
- Permalink
2022-07-27
12:47 AM
2022-07-27
12:47 AM
I cut the signal cable of the fam as the connection was flaky and I got tired of opening up the NAS. It now runs permanently at full speed.
Any way to disable that alert so it's not in the logs?
Message 1 of 2
- Mark as New
- Bookmark
- Subscribe
- Permalink
2022-08-25
12:20 PM
2022-08-25
12:20 PM
Re: RN314 - Disable log/warning for the 0RPM fan speed?
From SSH, edit /etc/frontview/sensors/RN314.conf as shown here:
chip "coretemp-isa-0000"
label temp2 "CPU"
compute temp2 @%35, @%35
ignore temp3
chip "it8721-isa-0a00"
ignore in0
label in1 "V5_0"
set in1_min 4.7
set in1_max 5.3
compute in1 @*1.732, @/1.732
ignore in2
ignore in3
label in4 "V3_3"
compute in4 @*1.2, @/1.2
set in4_min 3.135
set in4_max 3.465
label in5 "V1_2"
set in5_min 1
set in5_max 1.3
ignore in5
label in6 "V+12"
compute in6 @*61/14, @*14/61
set in6_min 10.8
set in6_max 13.2
set in7_min 3.135
set in7_max 3.465
label fan1 "System" (if zero doesn't work below, change to ignore fan1)
set fan1_min 400 (change 400 to 0)
ignore fan2
ignore temp1
label temp2 "System"
set temp2_min 1
set temp2_max 80
ignore temp3
ignore intrusion0
I'm not sure the system will accept a zero for the minimum, thus the alternative. Note that the alternative will also make the fan disappear from the "Performance" display in the GUI.
This will not survive an OS update -- you'll have to re-do it. To make it easy, keep a copy with a different name you can copy back to the original name.
Message 2 of 2
