× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
RN4220 Freeze
umita
RN4220 Freeze
Hi,
My costomer has a NAS box that freezes unexpectedly. And also, GUI is not working. OS version is 6.4.2. I've seen some out of memory errors from serial console. The only thing i can do is hard reset. I'm planning to upgrade firmware to a newer relese but i'm anxious that it can freeze during fw upgrade process. Can i upgrade it over ssh or cli? Can anybody share some cli commands for fw upgrade?
regards,
Umit
Model: RN4220X|ReadyNAS 4220 10Gbase-T (chassis only)
Message 1 of 3
mdgm-ntgr
NETGEAR Employee Retired
Re: RN4220 Freeze
OOM errors suggest a memory leak or trying to run too much or perhaps a very large number of snapshots with quotas enabled on the data volume.
You can send me the logs if you like (see the Sending Logs link in my sig)
To update via SSH you’d do e.g.
# cd /root
# wget URL
# echo /root/ReadyNASOS-6.9.3-x86_64.img > /etc/.flash_update
# rn_shutdown -r
If a zip file is downloaded you’ll need to unzip that to get the .img file.
Message 2 of 3
umita
Re: RN4220 Freeze
Hi,
Browser gui is not working but serial console and ssh is running. Which logs can i send to you?
regards,
Umit
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 671 views
  • 0 kudos
  • 2 in conversation
Announcements
