× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
RN716 with 10TB Disks
bigredbeast
Hi all, I have confused myself comparing the spec sheets and the HCL for the RN716x and need a bit of clarity if anyone can help?
1. Are 10TB disks supported in the RN716X ( I believe so as the HCL says yes)
2. Will the RN716x support 6 x 10TB disks
3. If so will it support all RAID configs for 6 x 10TB disks (I want RAID5)
4. Can I configure the 6 x 10TB RAID5 as one single volume
Thanks in advance.
Model: RN716X|ReadyNAS 716X Chassis
Message 1 of 3
Accepted Solutions
mdgm-ntgr
NETGEAR Employee Retired
Re: RN716 with 10TB Disks
1. Yes. Spec sheets reflect what was available when they were written.
2. Yes
3. Yes, but I'd recommend considering other RAID levels e.g. RAID-6, RAID-50 etc. In any case regardless of which RAID level you use be sure to backup your data. Don't store important data on just the one device.
4. Yes
Message 2 of 3
All Replies
mdgm-ntgr
2. Yes
4. Yes
Message 2 of 3
bigredbeast
Awsome, many thanks.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2880 views
  • 0 kudos
  • 2 in conversation
Announcements
