- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RND4000 SV1 Swap
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
My ReadyNAS RND4000 NV+ has just died. I have managed to chance upon another new and never used RND4000NV+ to replace it. How do I go about swapping them over, is there a process I should follow or is it as simple as swapping over the disks and rebooting?
Any help would be appreciated.
Thanks
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Now to clean up the files and think of a plan to make sure this does not happen again.
Thanks again for the help.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RND4000 V3 Swap
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RND4000 SV1 Swap
Hi @Junyar
Welcome to the Community!
NV+ has V1 and V2 so you need to make sure they are the same. How to tell NV+ V1 from V2.
You can just plug in the disks in the same order as with the Old NV+ then turn on the unit. It should boot normally given that the disks are still healthy and you should be able to access your data back.
It's good to hear that you were still able to find a replacement unit. If you have purchased that Brand new from a NETGEAR Authorized reseller you can try to contact NETGEAR Support and register your device and provide the Proof of Purchase. You might be able to take advantage of the Warranty.
Regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Junyar wrote:
They are both the NV+ V1, so a straight swap and reboot should be all that is needed. Will I have to reconnect and rename etc.?
If the firmware in the flash doesn't match the original NV+, then the replacement will install that version onto your disks. So it's best to set up the replacement with a scratch disk first, and then update the firmware if needed. That prevents the risks of a large downgrade causing issues (which could put your data at risk).
Once that is done, power down and migrate the disks (preserving slot order), and power up again. The settings are all on the disks, so there's no need to reconfigure anything.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Junyar wrote:
Thanks. How do I set up a scratch disk?
A scratch disk is just a SATA disk you happen to have that you are willing to use for this. It needs to be <= 2 TB in size, and it will be reformatted as part of the process - so any data on it will be lost. It doesn't need to be on the hardware compatibility list - it won't be in the system for long, and you won't be putting any of your data on it. It shouldn't be one of the disks in your old NAS.
@Junyar wrote:
Also I am not sure what firmware was on the dead one. Can I check?
If the NAS won't boot, then you can't easily tell the firmware. It is ok to use the current firmware (4.1.16) on the new NAS, as upgrading firmware doesn't carry the same risks as downgrading.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Junyar
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The best approach is to put a backup plan in place.
Given the age of your NAS (the replacement has to be at least 7 years old), I suggest getting a new ReadyNAS model with new disks. You can then copy over the data from the NV+, and repurpose the NV+ (making it a backup NAS).
