Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RNDU4000 disaster recovery?
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-04-05
03:47 PM
2012-04-05
03:47 PM
Hi,
I'm planning to buy Ultra4 for home use. I will definitely use XRaid. Of course - backup must be done frequently, but let's assume some sort of failure of ReadyNas itself after a warranty. Let's also assume that HDD's are fine. Is there a way to recover data from disks managed by XRaid? And I'm talking 3 or 4 disks in one volume.
Is it even possible to put drives to another (healthy) ReadyNas? What are the options?
Cheers,
Elliot
Cheers,
Elliot
Message 1 of 9
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-04-05
03:58 PM
2012-04-05
03:58 PM
Re: RNDU4000 disaster recovery?
elliot_pl wrote: Hi,
Cheers,
Elliot
Yes, you can put the drives in another ReadyNAS as long as it's running the same architecture.
Message 2 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-04-05
05:24 PM
2012-04-05
05:24 PM
And what about other options? Is mounting XRaid drives under linux possible for data recovery?
Message 3 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-04-05
05:44 PM
2012-04-05
05:44 PM
elliot_pl wrote: And what about other options? Is mounting XRaid drives under linux possible for data recovery?
Yes, you can use Linux to do the recovery.
Message 4 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-04-05
06:05 PM
2012-04-05
06:05 PM
Wow - very quick response for the second time 🙂 Thank you for that.
So one more question - if I understood correctly, XRaid is basically plain mdraid or something else?
Message 5 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-04-05
06:39 PM
2012-04-05
06:39 PM
It is a customized version of Raid as it is expandable both horizontally (adding disks) and vertically by increasing the size of the disks (one at a time). The expansion vertically will not take place until there are enough of the larger size for redundancy. In the case of a 4 bay unit that's two. For example my NVX units started out with 4x1TB drives (2.7TB net volume after redundancy and overhead). As I was filling up the volume, I replaced two to the 1TB drives with 3TB drives in both units and the net volume is now 4.5TB. (Note: Sparc based volumes will not expand until all drives are larger).
The correct name for the technology in the Ultra 4 is X-Raid2. Here is a description of the expansion of X-Raid2. The original Sparc based units had X-Raid and X-Raid2 is far more flexible.
Message 6 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-04-06
01:19 AM
2012-04-06
01:19 AM
Thank you for the answer. Yes, I'm aware that this is custom solution compared to traditional RAID. I have no questions regarding expanding XRaid2. I was rather wondering how to extract data from drives managed by it. yoh-dah wrote that it is possible under Linux. Right now I'm wondering how because you PapaBear confirmed that this is non-standard mdraid solution.
Message 7 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-04-06
02:45 AM
2012-04-06
02:45 AM
On x86 it's using mdadm to stop and start the RAID. It's using md raid. The X-RAID2 scripts are custom and proprietary though.
Sparc uses a custom mdconfig for Flex-RAID, but not x86 or ARM. x86 and ARM use md raid for both X-RAID2 and Flex-RAID.
You might want to have a read of this thread: http://www.readynas.com/forum/viewtopic.php?f=65&t=61168
Message 8 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-04-06
05:25 AM
2012-04-06
05:25 AM
Yes - that finally does it. This URL is what I was looking from the beginning. Thank you guys!
I really appreciate the help.
Message 9 of 9
