× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
RNDU4000
granitk
RNDU4000
Dear,
I allready purchesed the Netgear RNDU4000 with 4 bay disk station.
I'm looking to purches 4 x 8 TB hdd Baracuda 7200 with RAID 0
Can anyone tell can i user the 4x8 TB in my Netgear RNDU4000 in total  64 TB?!
Model: ReadyNAS RNDU4000|ReadyNAS Ultra 4 Chassis only
Message 1 of 5
Accepted Solutions
Guru
Re: RNDU4000
Clearly not, since 4x8 => 32.
I'm not sure if a single RAID-0 volume would work, but it is a very bad idea.  If one of your disks failed, you'd lose all 32 TB of data, and you'd need to restore everything.
A much better approach (which will work) is to create 4 volumes of 8 TB each (one per disk).  You then need to balance the storage across 4 volumes manually (creating the shares you want on each disk).  That is quite simple when you have volumes this large.
@granitk wrote:
I'm looking to purches 4 x 8 TB hdd Baracuda 7200 ...
Not the best disks for a NAS.  If you like Seagates, I suggest you get Ironwolf drives instead.
Message 2 of 5
All Replies
Guru
Re: RNDU4000
Message 2 of 5
granitk
Re: RNDU4000
Dear @StephenB thank you for you replay.
64TB it was my mistake because i mean 32 TB hahaahhahhahaha sorry
So if I can use 4x8TB with my NAS i also can use X-raid with 2x2 disk's mirroring?! My last firmware is 6.7.4
I'm also interested to know can i user 4x10TB nas hdd 7200 with X-Raid with my nas model: RNDU4000
Message 3 of 5
Guru
Re: RNDU4000
If you use X-RAID single redundancy (RAID 5), then 4x8TB would be 24 TB of storage (~21.8 TiB)
X-RAID with Dual redundancy (RAID 6) would be 16 TB of storage (~14.5 TiB).
There other RAID modes - for instance RAID-10 would also give you 16 TB of storage.  Performance is better than X-RAID dual redundancy (RAID-6) but the protection isn't quite as good.  RAID-6 protects against all 6 combinations of two-disk failures.  RAID-10 protects against 4 of those combinations.
4x10TB is also available in OS-6 systems.  Though I don't recall a posting here from an Ultra user, as far as I know those disks are compatible with the ultra hardware.
Resync/Volume build time goes up as the volume increases, and it will take quite a while with big disks on the ultra.  However, once built, it should work.
Message 4 of 5
granitk
Re: RNDU4000
Dear @StephenB thank you for your comment 🙂
I will try with 4x10 TB 🙂
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3967 views
  • 1 kudo
  • 2 in conversation
Announcements
