- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RR2312 noise levels
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thinking of buying a ReadyNAS 2312 when it becomes available in Europe.
This would be in my rack in the garage.
Can anyone who has one tell me how noisy it is? I worry that it’ll have a ton of VERY LOUD fans to be able to dissipate the heat from 12 HDDs.
Thanks for your help!
André
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Per the datasheet it has five 40mm fans. The noise spec is < 28 dba, which is surprisingly quiet. Hopefully someone from Netgear ( @BretD ?) can confirm that spec.
https://www.netgear.com/images/datasheet/storage/RR2304_RR2312_RN3138_DS.pdf
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RR2312 noise levels
Completely missed the noise rating on the data sheet!
Thanks so much 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm gonna go with what the datasheet says, they do extremely detailed testing to make sure that information is accurate.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
My concern with the RR2312 - it may NOT fit into your Server Rack... it's 909mm in depth -vs- 707mm for the RR3312/4312X models.. the other is the 4x1GB ports - why not just have 2x10G avail as an upgrade.. especially if thinking with an all SSD Solution
- Mark as New
- Bookmark
- Subscribe
- Permalink
My rack is a 1000mm depth, so should be fine.
Does the RRR2312 come with rails? Seems like a bit of a pain having to take it all apart very time you want to fiddle with the HDDs...
