× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Random shutdowns resulting in do_exit+4ac error on LED readout
LoftySnowman
My new ReadyNAS is repeatedly shutting down for an unknown reason. The LED readout on the front of the device displays "do_exit+4ac". Does anyone have advice on how to diagnose the root cause of this issue?
Model: RN21400|ReadyNAS 214 Series 4- Bay (Diskless)
Message 1 of 14
Accepted Solutions
Hopchen
Prodigy
Re: Random shutdowns resulting in do_exit+4ac error on LED readout
Hi @LoftySnowman
Thanks for the logs. The good news is that your disks, raid and filesystem are fine. That is the most important.
I can see the boot issue happening and in fact I can see that the NAS ends up in a boot-loop from time to time. Seemingly, the NAS boots up but then immediately reboots itself.
Mar 13 18:16:43 readynasd[2068]: readynasd log started
Mar 13 18:16:44 readynasd[2068]: readynasd started. (restarted=0)
Mar 13 18:17:01 readynasd[2068]: Using fan mode: quiet
Mar 13 18:17:02 readynasd[2068]: ReadyNASOS background service started.
Mar 13 18:17:42 readynasd[2068]: The system is shutting down.
Mar 13 18:18:35 readynasd[2068]: Exit main thread by SIGTERM.
Mar 13 18:18:35 readynasd[2068]: readynasd is halted.
-- Reboot --
Mar 13 18:25:41 readynasd[2073]: readynasd log started
Mar 13 18:25:42 readynasd[2073]: readynasd started. (restarted=0)
Mar 13 18:25:59 readynasd[2073]: Using fan mode: quiet
Mar 13 18:26:01 readynasd[2073]: ReadyNASOS background service started.
Mar 13 18:26:21 readynasd[2073]: The system is shutting down.
Mar 13 18:26:39 readynasd[2073]: Exit main thread by SIGTERM.
Mar 13 18:26:39 readynasd[2073]: readynasd is halted.
-- Reboot --
Mar 13 18:27:48 readynasd[2073]: readynasd log started
Mar 13 18:27:49 readynasd[2073]: readynasd started. (restarted=0)
Mar 13 18:28:07 readynasd[2073]: Using fan mode: quiet
Mar 13 18:28:09 readynasd[2073]: ReadyNASOS background service started.
Mar 13 18:28:22 readynasd[2073]: The system is shutting down.
Mar 13 18:28:45 readynasd[2073]: Exit main thread by SIGTERM.
Mar 13 18:28:45 readynasd[2073]: readynasd is halted.
-- Reboot --
I dove into the kernel logs and found a successful boot sequence and a boot sequence where the NAS fails (and then reboots). I compared those and they are mainly the same except for the end of boot. Here is an extract of the end of a successful boot. It ends with the NIC going up and ready.
kernel: eth [al_eth_1]: set link speed to 1000Mbps. full duplex.
kernel: al_eth 0000:00:03.0 eth1: Link is Up - 1Gbps/Full - flow control rx/tx
kernel: IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
Here is the end of a failed boot and we can see that the NIC does come up not correctly.
kernel: al_eth 0000:00:03.0 eth1: al_eth_down
kernel: [eth rx] warn: dma state didn't change to Disable
kernel: [eth rx] warn: failed to change state, error -110
kernel: configured MAC to RGMII mode:
kernel: al_eth 0000:00:03.0 eth1: using MSI-X per Queue interrupt mode
kernel: libphy: al mdio bus: probed
kernel: al_eth 0000:00:03.0 eth1: phy[5]: device 18:05, driver Atheros 8035 ethernet
kernel: al_eth 0000:00:03.0 eth1: phy[5]:supported 2ef adv 2ef
kernel: IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
kernel: al_eth 0000:00:01.0 eth0: al_eth_down
systemd-shutdown[1]: Sending SIGTERM to remaining processes...
-- Reboot --
To me, this looks like either a hardware issue or the NIC driver possibly getting "wedged". So, either an issue with the chassis or an issue with the OS software. There are things you can do to diagnose this further but if you are still under hardware warranty, I would raise a ticket with NETGEAR and let them see if the chassis is faulty.
Are you still under HW warranty?
Cheers
Message 9 of 14
All Replies
Guru
Does it run for a while, and then crash?  Or does it fail to boot?
Also, what firmware are you running?
Message 2 of 14
LoftySnowman
The NAS is running firmware 9.6.5. It will typically stay online for a day or so before shutting down again. I have four 10TB drives slotted into the appliance with a RAID-10 configuration.
I cannot interact with the NAS once that error occurs. If I perform a hard shutdown, then I am only able to reboot with the network cable disconnected. Once booted, I can reconnect the network cable and its fine again until the next shutdown.
Message 3 of 14
LoftySnowman
It was just turning back on when you last replied. I was able to connect and download the logs before it shutdown again.
Message 4 of 14
Hopchen
Prodigy
Hi @LoftySnowman
It is hard to tell what is going on exactly. I will be happy to take a look at the logs for you, if you want.
Download the log-set and upload to a Google link or similar and PM me the link.
Cheers 🙂
Message 5 of 14
LoftySnowman
PM sent. Thanks for offering to help.
Message 6 of 14
Hopchen
Prodigy
No problem.
I will take a look. It is quite late here in Europe so might be tomorrow before I get time 🙂
Message 7 of 14
LoftySnowman
I appreciate it. Note that I made I typo in an earlier reply. I am running the 6.9.5 firmware.
Message 8 of 14
Hopchen
Prodigy
Hi @LoftySnowman
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
Cheers
Message 9 of 14
Guru
I agree, though I'd start by requesting an RMA.  They will check it out.  You can request the RMA at my.netgear.com.
Note that most RN214 should still be under warranty, as it was released in October 2015 (and has a three year warranty for the original purchaser).  But if you purchased early, then don't delay.
Message 10 of 14
LoftySnowman
If I did an RMA and popped the disks into a new unit, would it wipe the disks? I have been trying the second ethernet port and haven't yet seen another shutdown. I did purchase this NAS in the middle of February, so it should still be under warranty.
Message 11 of 14
Hopchen
Prodigy
Hey again
The data and the OS and all the settings are stored on the disks. You can simply move the disks into a new unit and power it up.
https://kb.netgear.com/22895/ReadyNAS-OS-6-Migrating-a-volume
To migrate a volume to a diskless ReadyNAS OS 6 system:
  1. Gracefully shut down the new (diskless) storage system.
  2. Remove each disk in the volume from the old system.
  3. Install each disk in the volume into the new storage system.
  4. Turn on the new system by pressing the Power button.
Of course, always make sure you have backups sorted before doing anything 🙂
Message 12 of 14
LoftySnowman
Thanks for your help diagnosing the issue. I did switch over to the second ethernet port. The ReadyNAS stopped shutting down for a while. After a couple weeks, the random shutdowns started again. This time I upgraded the firmware to 6.10.0 and the shutdowns got worse. With your suggestion I did work with customer support and am opening an RMA for the unit. I will likely use it as a non-primary device from now on, given how quickly the first one failed and how difficult it was pulling my data off of it onto a backup.
Message 13 of 14
Sandshark
Sensei
The NIC uses +5VSB (5 volt standby) power in order to support WoL.  That's a separately regulated bus within the NAS for just the NIC and power on/off circuitry, and yours sounds like it is failing, as that will cause both random shut-downs/power cycles and failure to boot properly when it does..  It's not repairable (at least by the user), so I hope you are under warranty.  It is unlikely the external supply is at fault, but you could try another if you have one.  It's not even enough of a chance that it would work that I recommend you buy one to try.
The +5VSB stays on all the time, even when the NAS is "off".  If your NAS has an opportunity to get hot when it's "off", that can stress the +5VSB regulator to the point of failure.
There is a chance there is just a build-up of dust, pet hair, etc. (especially in a smoking household where the smoke residue serves as "glue") that's causing the regulator to overheat.  If you aren't in warranty, opening the case and blowing out any dust could help, though perhaps not for long if the regulator is already overstressed.  Note:  Don't let the fan spin really fast from blowing out the dust.  Use something to hold it stationary.  Over-revving the fan is bad for the bearings.
Message 14 of 14
Top Contributors
Discussion stats
  • 13 replies
  • 2362 views
  • 1 kudo
  • 4 in conversation
Announcements
