- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS 102 - Blinking power light after firmware upgrade
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recently upgraded to the latest firmware for my device and after rebooting the Power & Backup lights are rapidly blinking (blue), I have unplugged the device to try and reboot and also used the system reset button on the back (with a paperclip) without success. I have tried botting up without the disks - the lights still blink the same. I am wondering if the firmware update bricked the machine or if there is something else I can try? Many thanks for your help.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@burtonrhodes wrote:
Curious... can I just put my 2 drives in the new unit? Or is there a procedure for upgrading a NAS unit - in this case: RN102 -> RN422
You can, but it is best to put a scratch drive in the RN422 first, and update it to the current firmware.
If the firmware in the RN422's flash is older than what you were running in the RN102, then the boot loader will be forced to downgrade to the version in the flash. That's because it needs to switch from arm->x86 as part of the migration. That downgrade might not be supported (so there is risk that something will go wrong). Upgrading the new NAS to the current firmware first prevents a downgrade from happening.
After that, just shut down, remove the scratch disk, and migrate your RN102 drives to the RN422. Keep the two drives in the same bays.
If you have arm-based apps on the RN102 (for instance plex), you will need to remove them after the migration. Then install the x86 versions.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNAS 102 - Blinking power light after firmware upgrade
Welcome to the Community!
Have you checked the Status of the NAS on RAIDar? ReadyNAS 100 series should follow an upgrade path when updating, were you on the latest firmware before you updated to the 6.10.1?
If in any case the NAS fails to boot, you may want to try doing USB Boot recovery. This does not affect the data on the disk but hopefully you have back up of your data, this reload current firmware onto your ReadyNAS storage system.
HTH
Regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the quick reply! RAIDar "could not find any NETGEAR storage on my network". I was upgrading to the latest firmware and had the previous one installed (6.10.0??). I am fairly diligent about upgrading my firmware... perhaps too much so 😮
I will give the USB method a try and report back!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well, the USB method doesn't seem to be working. I ordered a NETGEAR ReadyNAS 422 yesterday (as a precaution) that should arrive tomorrow. My 2 harddrives currently have data I very much need to keep. Curious... can I just put my 2 drives in the new unit? Or is there a procedure for upgrading a NAS unit - in this case: RN102 -> RN422
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Followed your advices with a scratch drive and worked well. Upgraded the firmware. Powered down. Then put only one volume in (for safety). Booted back up - NAS said it was upgrading Firmware. After it finished, everything seemed to be in order. Powered down and put the other drive in. Now drives are syncing up (degraded) - but should be complete in several hours. Thanks again for the help.
