- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS 314 running firmware 6.9.5-unable to access home folder admin
- Mark as New
- Bookmark
- Subscribe
- Permalink
ReadyNAS 314 running Firmware 6.9.5
Was using a Windows 7 desktop as sole admin (no other users) and was able to see and access home page/admin using File Explorer.
Have switched to a new desktop with Windows 10 Pro (Version 1809) and can no longer see or access home page/admin using File Explorer.
I can see it and access it through the Radiator Admin Page, but simply does NOT show up in File Explorer. Most inconvenient.
I tried turning off SMB protocal through the "access" tab, and then turning it back on again--but that did NOT work.
Any other suggestions would be appreciated. Thank you.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is happening because you aren't using the NAS admin credentials in the Windows 10 system. To solve this, go into the Windows Credential Manager and
- delete any saved credentials for the NAS (both IP address and hostname)
- add new credentials using "admin" as the username, and the NAS admin password (again both IP address and hostname).
Then reboot the PC.
Though in my option a better option is to simply stop using the admin folder. Home folders aren't as easy to restore from backup as other folders, and some apps/services won't work with home folders (for example, DLNA). So personally I'd
- copy the stuff in admin to a new share
- delete the contents in admin
- disable SMB for the home folder in the share settings.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Then reboot the PC.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNAS 314 running firmware 6.9.5-unable to access home folder admin
Worked like a charm AND I appreciate your observations about its deficiencies relative to using it to begin with. Thank you.
