TheDrSavage
Feb 29, 2016Aspirant
ReadyNAS NV+ V2 Hard drive set up
Hi
Bit of a newbie question, Sorry.
I ReadyNAS NV+ V2, Got 2x2tb 2x4tb WD NAS red Drives.
Want 2x2tb mirrored for photo, music and home videos, for secure back up. So mirror 1
Then 2x4tb as stand alone drives not raid, for 1x4tb for tv shows and 1x4tb for films. Dont want raid on them as they can be downloaded again.
How do I configure or set this up ? before you ask, yes Ive got nearly 3tb of films and over 3tb of tv shows. hence why the drives are on thier own.
I have already factory reset the unit and put in the 2 x 2tb and put them as xraid2 which gave me 1.8tb space but when I put in the 4tb it added it to the raid and total was 3.8tb availble ??
Any help and advice, many thanks
You needed to select flexraid when you did the factory reset, and then create 1 RAID-1 2 TB volume (for the two 2 TB drives), and two 4 TB JBOD volumes (one for each 4 TB drive)
The manual is probably the best place to start: http://www.readynas.com/download/documentation/UM/RAIDiator5-3_Home_SW_en_Nov711.pdf
You'll need to do the reset again, I suggest doing that with only the 2x2TB drives installed.
- TheDrSavageAspirant
Thanks StephenB, thats exactly want I needed. Will set it off again.
Hi,
ok ok after a few attempts, still can't mix raid 1 on 2 x2tb with JBOD on 2x4tb. The nas makes both sets raid 1, so 2x2tb is c: raid 1 and 2x4tb is d: raid 1.
tried to put all as JBOD, but it did exactly the same thing, so did a format, good thing I was on nights, it took 2 night shifts and sleeps during the day.
i can get both 2TB to raid but can't get 4TBs to stand alone.
cant see in the dashboard where to format 1x4TB after creating 2x2tb raid 1.
any idea ?
Thanks
