- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS NV+ needs new power supply
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello!
Like many other posts here, I've experienced a power supply failure on my ReadyNAS NV+ RND4000v1. I understand these devices are end of life, but I would like to see if I can get a power supply replacement in order to get it working again and migrate to a newer device. Any help is appreciated.
JFB
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNAS NV+ needs new power supply
If you are planning to get a new Readynas, there is a procedure to migrate your disks from an old Readynas to the new unit. You would require Netgear support to help you with this, it is important not to insert the disks into the new unit until instructed by Netgear, and during the migration you would need to copy your data to another location (in other words you'd need some space somewhere to copy all your data).
if you went about it this way you would not need to get a new PSU, unless of course you wanted to repurpose the NV+ .
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello vandermerwe,
Yes, I was hoping to get a new power supply in order to get the ReadyNAS NV+ running again ASAP as I need access to that data for time critical assignments. I would then start a plan to migrate off the device onto a new device. I understand it's simply not a "swap disks" kind of thing. There is a LOT of data I would have to move to whatever temporary location I can come up with and that will take time as well. Is there a way I can get a PSU replacement?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not sure where you are located @jfb1 but you may find this link helpful http://www.evercase.co.uk/CompatibilityListReadynas.htm
as well as this one http://www.downloads.netgear.com/files/GDC/READYNAS-COMMON/Replacing%20the%20PSU.pdf
- Mark as New
- Bookmark
- Subscribe
- Permalink
or a better price here http://www.ebay.co.uk
Both linked companies here and in post above ship worldwide
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks bedlam1!
I'm in the US. Yes, I can find a PSU replacement but they are pricey. My understanding was that Netgear was honoring warranties because of faulty PSUs on the Netgear NV+. At least that is what I picked up from other posts here. I don't want to shell out a couple of hundred dollars on a PSU for a device that is end-of-life if I don't have to. But perhaps I will have no choice.
Thanks again,
JFB
- Mark as New
- Bookmark
- Subscribe
- Permalink
The replacements were only for a limited range of Serial No.'s if I remember correctly
Supply and shipping from UK would be about $100
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks bedlam1.
Do you happen to have the link to the affected serial #s? I cannot seem to locate on Netgear site. I'll keep searching. Thanks for the additional info on replacement PSU.
JFB
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks much mdgm.
Appears that my NAS is not within the serial # range. 😞 Shot in the dark, but wondering if Netgear has any compatible PSU's lying around? These devices are end of life. Ha! Really don't want to have to spend more than what the device is worth just to get a third-party replacement PSU. Yes, I am whining.
JFB
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello jfb1,
RND4PSU1-10000S is the part number for ReadyNAS NV+v1 PSU. You might want to try your luck checking if online resellers have this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello jfb1,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi jfb1,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
