- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS RND2000 duo
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Everyone
Can anyone help me, I have just got hold of a RND2000 2nd hand. it has a 1tb & a 750Gb drives in it
I am trying to do a factory reset as per manual but all i keep getting is the lights on the front flashing approx every 5 seconds
I have tried with drives in & out but no difference
I have also tried to find it on my network using RAIDer but it cannot find any drives attached
Has anyone got some suggestions I could try
Thanks in advance
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNAS RND2000 duo
@Whizzer wrote:
I have also tried to find it on my network using RAIDar
Try booting up the Duo w/o disks, and see if RAIDar finds it.
You can erase the disks in a Windows PC (using Seatools or WD's Lifeguard tools), or unformat them use Windows Disk Manager.
Then power up the NAS with the disks installed, and it should do a factory install.
If you use the default XRAID/RAID-1 you'll end up with 750 GB of storage. You should use disks that are the same size. Your NAS should be able to take up to 2 TB drives. The Duo v2 (which says Duo v2 on the front panel) can handle larger drives.
This will be much slower than current ReadyNAS (Netgear stopped shipping these products quite a while ago). Note it only supports SMB 1.0 - which is being deprecated by Microsoft in Windows 10, and Apple in Calalina. You can enable SMB 1.0 in Windows 10 - not sure if this is possible with Catalina.
