× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNAS up and running
carson
Well I got my Duo last Friday to replace my Stora that I was extremely unhappy with. The only real fault I can find so far is that the factory reset procedure isn't very well documented and that cost me a lot of time. I was even on the phone with Netgear support for a very long time and they were giving incorrect directions on how to do this. I will give them a lot of credit because they called me back about a half hour later with correct instructions on how to do this and it was a breeze from then on.
So I'll say so far so good.
Carson
Message 1 of 2
arjoseph1
Tutor
Re: ReadyNAS up and running
Good to hear that! You may want to visit ReadyNAS FAQ in the link below:
http://www.readynas.com/?cat=50
You will find a lot of helpful topics in it. I hope it helps next time. 🙂
Message 2 of 2
Discussion stats
  • 1 reply
  • 5062 views
  • 0 kudos
  • 2 in conversation
Announcements
