t1moth
Jun 13, 2020Aspirant
Readynas Duo problems as media server with Squeezebox
Hi , sorry bit of a noob. I am using Readynas Duo as a media server to stream music using my Logitech squeezebox. I have the Tidal app instelled on teh squeezebox but if it only works if I connect to my PC based logitech media server. I can connect to the readynas and play media files stored there but the Tidal app dissapears. I want to be able to use Tidal without having to switch on the PC, is this possible?
I don't use squeezebox myself, so I can't help much.
But I am wondering if you have installed the squeezebox server on your NAS, or if you are only using ReadyDLNA.
- t1mothAspirant
Hi, I sucessfully installed Logitech Media Server on the ReadyNas, I'm also using Ready DLNA for videos.
I believe Tidal also needs a plug-in installed in the server. https://support.tidal.com/hc/en-us/articles/115005871329-Squeezebox
