× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Readynas Pro 2 max memory
n_damian
What is max memory (ddr3) size which i can install with one slot (rndp2000)?
Model: ReadyNASRNDP2000|ReadyNAS Pro 2 Chassis only
Message 1 of 13
n_damian
Re: Readynas Pro 2 max memory
OS6
Message 2 of 13
JennC
NETGEAR Employee Retired
Hello n_damian,
Are you running OS6 on your ReadyNAS Pro 2?
This discussion might also help: ReadyNAS RAM Upgrade - Needed?
Message 3 of 13
n_damian
Yes, i'm using OS 6 on RNDP2000.
RAM is cheap so I want to install 4GB. I know that 2GB will work, but what about 4 GB?
Message 4 of 13
JennC
Hello n_damian,
From what I've heard, users have used 2GB, I havent heard of 4GB.
Message 5 of 13
Guru
I think the ceiling is 2 GB per slot (Intel Atom chipset limitation).
Message 6 of 13
dsingh
Message 7 of 13
dsingh
Message 8 of 13
Guru
To be more clear, the Pro-2 only has one slot.  So if I'm right on the intel atom constraint, the memory is limited to 2 GB.
Message 9 of 13
dsingh
I don't think that it is a constraint of the chipset.  Could be a limitation imposed by the firmware.  This limitation might have been relaxed in OS6 - something that I have not tried yet.
Message 10 of 13
Guru
There is an old post that claims it is.  In any event, I did search the forums, and I can't find anyone who has gotten more than 2 GB working on the pro-2 or ultra-2.  You can get more on the larger units (I have 2x4GB working on my pro-6).
Message 11 of 13
dsingh
Here is the spec from Intel clearly stating that the processor supports 4GB of RAM ... http://ark.intel.com/products/49490/Intel-Atom-Processor-D525-1M-Cache-1_80-GHz
Message 12 of 13
Guru
It will support 2x2GB.  But there's only one slot in the pro-2.
Message 13 of 13
Top Contributors
Discussion stats
  • 12 replies
  • 5890 views
  • 2 kudos
  • 4 in conversation
Announcements
