× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Readynas duo hard drive failure
tokel
Hello! I have a ~10 year old readynas duo (v1 or v2) with 2x 1tb hard drives in. Now it has not been powered for many years, and I want to get the data of the disks. However, when I boot I get this (in Swedish):
https://ibb.co/Nn9yRKr
"Felaktiga diskar hittades" = Incorrect disks were found
Does this mean that both of the disks have failed?
Now, whatever I do I cannot access the admin page. I can only ping the device, but it's not possible to access the admin page and it's also not possible to mount anything on the network. It's simply completely dead. What can I do?
Edit: The front of the device is just a blinking blue LED.
Model: RND2000|ReadyNAS Duo Chassis only
Message 1 of 6
Accepted Solutions
Guru
Re: Readynas duo hard drive failure
You can try powering down the NAS and booting up with only disk 2 installed (keeping it in slot 2).
You can also connect disk 1 to a windows PC, and test the disk with vendor tools (lifeguard for Western Digital, seatools for Seagate).  If it is readable, you can extract data with r-linux for windows ( https://www.r-studio.com/free-linux-recovery/ )
Message 2 of 6
All Replies
Guru
Message 2 of 6
tokel
Thanks for the reply, that did the trick (only running with disk 2)! Now I'm copying all files to a safe place. I'm thinking about buying a SATA->USB adapter. Do you know any good software (windows or linux) to test the failed hard drive to see if it's actually not working?
If I do a factory reset of the device now, where is the OS stored? Is it stored on some internal drive, or is it stored on the HDD?
Message 3 of 6
Guru
The OS is stored on the hard drive(s) in a small partition that isn't normally accessible.
Having an adapter like that is often useful.  For disk testing, I use Lifeguard (Western Digital) and SeaTools (Seagate).  There are other options out there (HDDScan being one), but generally I stick with the vendor tools.
Message 4 of 6
tokel
Thanks for saving my data!
Message 5 of 6
Guru
I'm glad I could help.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1591 views
  • 2 kudos
  • 2 in conversation
Announcements
