× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Reply
Replacement Disk Caddys
maccaz
Hi
I'm looking to buy some replacement disk caddys. Unfortunately the ones I have seemed to have snapped on removal (no special removal just pressed the button then little bits of plastic came off them - I've not taken them out in about 3 years so maybe they're just old).  These are for a ReadyNAS Pro.  I've checked eBay and the like and can't seem to find anything in the UK.
Anyone have any links to get some?
Thanks!
Message 1 of 5
MCEComputers
Apprentice
Re: Replacement Disk Caddys
I have purchased a few from this seller on eBay, but I am in the US. He does not list the UK on his ship to list, but it may be worth an email to see if he will ship to you.
https://www.ebay.com/itm/115478454296?hash=item1ae30d6018:g:IMwAAOSwm-li4~Oe&amdata=enc%3AAQAHAAAAoG...
Message 2 of 5
MCEComputers
Apprentice
Here are a couple in the UK:
https://www.ebay.com/itm/265952456086?hash=item3dec006d96:g:4bYAAOSwMpNh5ePh&amdata=enc%3AAQAHAAAAoN...
https://www.ebay.com/itm/234744603289?hash=item36a7de6299:g:QI8AAOSw4wVjL1tR&amdata=enc%3AAQAHAAAAoH...
It may be easier to find a deal on a ReadyNAS being sold as parts only that still has the caddies included.
A piece of tape on the lever will work until you find replacements.
Message 3 of 5
Sandshark
Sensei
Yours are the old round-button ones?  Are they not latching or won't open?  Difficulty opening them is the norm (VERY poor design), and most users simply use a bent paper clip or jeweler's screwdriver to press down on the actual metal latch behind the plastic lever.
When purchasing replacements, the ones for a legacy desktop unit with the square releases are far superior.  But ones for a newer native OS6 unit or any rack-mount unit will not work.  Unfortunately, no other brand will work, either.
The going price for these caddies is around $30- to $40 US, so finding a cheap non-working NAS with caddies can be your best bet if you need to replace them all.  Of course, buying a whole NAS will up the shipping cost significantly.
Message 4 of 5
maccaz
Hi
Thanks for the replies - yes they're the round button ones - unfortunately bits broke off them which was holding the drives in place - now with the drives pushed in the latch doesn't catch so they're always open and prone to coming loose with the vibration.
I'll see if I can find a none-working drive as I need around 5 of these!
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 274 views
  • 0 kudos
  • 3 in conversation
Announcements
