× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Replacement disks RN102
DRC49
Hi ,
I've had a Seagate STM1000DM003 hard disk Fail. I no longer seem to be able to purchase the same disk locally but have ST1000DM010 1Tb  and or ST2000DM008 2Tb drives available locally. These are not on the RN102 hardware compatibility lists but AFAIK are latter models of the same drive. Has anyone ever used them or had any problem using them in an RN102.
Model: RN102|ReadyNAS 100 Series 2- Bay
Message 1 of 3
Accepted Solutions
Guru
Re: Replacement disks RN102
@DRC49 wrote:
Hi ,
I'd get a Seagate Ironwolf - current model number for 1 TB is the ST1000VN002.
If you must get a Barracuda, then get the ST1000DM010.  The ST2000DM008 uses SMR technology, which is not a good choice for RAID.
Message 2 of 3
All Replies
Guru
@DRC49 wrote:
Hi ,
Message 2 of 3
DRC49
thanks Stephen
I have ordered ST1000VN004 disks as replacement.SInce one has failed the other may not be too far from failure so I'll  upgradie both.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1134 views
  • 0 kudos
  • 2 in conversation
Announcements
