- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Replacement fan for ReadyNas 600
- Mark as New
- Bookmark
- Subscribe
- Permalink
I need to find a replacement fan for the readynas 600, as the one inside has gotten loud.
The original fan was a Jun Yih Shyang Ent. Co. Ltd jhd-03009a12, which I can't find anywhere.
An apparent replacement is a Sirverstone FX-121 series which is no longer made (I called Silverstone) and I can't find anyone that has leftover supply.
Does anyone have any idea where a suitable replacement/substitute can be found?
Some useful links:
Silverstone FX121 on Newegg: http://www.newegg.com/Product/Product.aspx?Item=N82E16835220002
JHD-0300 series specs/exterior engineering drawings: https://www.scat-technology.ru/docs/catalogues/fans/crossflow_fans.pdf
I know the 600 is old but is completely functional (after a couple of fan and power supply replacements!)
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Replacement fan for ReadyNas 600
Not sure about which 3rd party fan replacements are available for the Infrant ReadyNAS 600, but considering the age of the ReadyNAS 600 (you've probably had it over 10 years) it might be about time to consider getting a new ReadyNAS.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have had it over 10 years, and it continues to serve its purpose perfectly fine. I don't really need a new one for what I use it for.
I do also have an 18TB Pro6 dedicated to offline tivo storage. Thats alot of TV!
But thanks for reading.
For now its working with the crossflow unplugged disks at 114, cover off.
Still would like to find a substitute fan for the original.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've never owned a 600, but am wondering if this would fit: http://www.amazon.com/Dyantron%C2%AE-CF-003-Crossflow-Servers-Enclosures/dp/B009SEN4Q6
It's 5 mm longer, and is noisier. It has a 3-pin connector.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It looks like this would work assuming the extra 5mm is split equally on both sides of the length. If its all on the left, it might be a tight fit.
Assuming of course the screw holes line up. (I would assume its a standard.)
The original does have a 3 pin connector, so that is probably fine.
The other big question is if the cord is long enough.
Thanks.
