Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
SYS FAN fails "out of spec"
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-29
11:51 AM
2013-06-29
11:51 AM
So for a while now I've been happily using a Noctua for my system fan (temps read rather high when the aircon is off) and a Zalman for a CPU fan (runs great). This is all on my RNPP (see my sig for details).
I decided to swap the Noctua for a Noiseblocker NB-eLoop B12-4 Ultra Silent Bionic Blade Fan because it can ramp up to faster speeds and push more air. I updated to 4.2.23 just before doing this fan swap, let the RNPP reboot and saw that all was fine.
I plugged the Noiseblocker into the same port ( http://i.imgur.com/pytAE13.jpg ) and after starting the NAS, the new fan spins up just fine.
I go to the Health page and for some reason the Noiseblocker stops spinning randomly with the error "FAN SYS failed" and "out of spec" ( http://i.imgur.com/64foOaT.png ) and I can see the old issue whereby Health reports FAN SYS, FAN CAS and FAN CPU. I went back and re-installed the ToggleSwitchProCPUFan_1.0-x86.bin addon twice and finally FAN CAS disappeared (see previous screenshot), yet the NAS keeps turning the Noiseblocker off.
Log:
Sat Jun 29 21:39:53 AST 2013 Fan 1 has failed (SYS 0 rpm).
Sat Jun 29 21:35:28 AST 2013 Fan will be recalibrated over the next few minutes.
Sat Jun 29 21:32:31 AST 2013 System is up.
Is the Noiseblocker honestly 'out of spec' in terms of RPM/power draw for the RNPP? I wouldn't think so!
I wouldn't mind a fix that led me to use USB/external power to keep the Noiseblocker running at full speed since I can live with the added noise.
Log:
Model: ReadyNAS Pro Pioneer Edition [X-RAID2] - Firmware: RAIDiator 4.2.23
Model: ReadyNAS NV+ [X-RAID] - Firmware: RAIDiator 4.1.7 [1.00a043]
Message 1 of 8
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-29
12:30 PM
2013-06-29
12:30 PM
Re: SYS FAN fails "out of spec"
TechZ wrote: So for a while now I've been happily using a Noctua for my system fan....
I decided to swap the Noctua for a Noiseblocker NB-eLoop B12-4 Ultra Silent Bionic Blade Fan....
I go to the Health page and for some reason the Noiseblocker stops spinning randomly with the error "FAN SYS failed" and "out of spec"....
Judging from what a quick Google search showed, your new Noiseblocker fan draws 320mA at 12V. That's more than FAN2's 250mA max, so yes, it's out of spec.
The Noctua fan you switched from draws only 1.08W at 12V; its current consumption will remain within spec across its entire RPM range.
2 × Pro 6 [Main & Backup] – XRAID2 Dual-Redundant (RAID6): 14.53TB (110MB/s Write, 123MB/s Read)
- CPU: 2.4GHz E6600 SL9ZL - RAM: 8GB (PSD28G800K) - BIOS: 07/26/2010 - OS: 6.10.3 w/ custom kernel - Drives: 6 × ST4000VN000 / ST4000VN008
Fans: Noctua NF-S12A FLX (Case), NF-R8 PWM (CPU), NF-R8 w/LNA (Power Supply) - USB: STGY8000400 - UPS: APC BR1000G
- CPU: Standard 1.8GHz Atom D525 - RAM: 2GB (CT25664BC1067) - BIOS: 11/02/2011 - OS: 4.2.31 - Drives: 2 × ST4000VN000 - Fan: Noctua NF-B9 - USB: ST31000340
Message 2 of 8
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-29
12:49 PM
2013-06-29
12:49 PM
Well, that certainly wasn't what I was expecting. But thanks, at least it clears up what is going wrong.
Now I need to find either something like this ( https://dx.com/p/usb-2-0-to-sata-ide-5- ... lack-10113 - it shows an img where its got sata-->molex, I have molex to 3pin) to power the fan externally OR an alternative fan that can push this much air at 250mA or less.
I would think that the RNPP could simply provide 250mA and the fan run at the speed it can with the given power, since both the RNPP and the fan are variable.
Message 3 of 8
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-29
07:36 PM
2013-06-29
07:36 PM
TechZ wrote: Now I need to find either something like this ( https://dx.com/p/usb-2-0-to-sata-ide-5- ... lack-10113 - it shows an img where its got sata-->molex, I have molex to 3pin) to power the fan externally
When I replaced the fan in my Pro Pioneer power supply, I chose to power it directly from one of the 4-pin power-supply plugs so I could experiment with its low-noise adapters without having to open the PSU case every time. The Noctua NF-R8 fan came with an appropriate adapter; you can find one by searching the web for 4 pin to 3 pin atx fan. Shouldn't cost more than a couple dollars.
The only thing is, if you do it that way you'll no longer have variable-speed control for your case fan, so you'll have to run it at its maximum speed (and maximum noise level) all the time.
TechZ wrote: OR an alternative fan that can push this much air at 250mA or less.
Well, the ReadyNAS designers chose the stock fan because it provides sufficient cooling at low-enough current... And with variable-speed control, it'll probably be quieter than the single-speed Noiseblocker fan most of the time.
TechZ wrote: I would think that the RNPP could simply provide 250mA and the fan run at the speed it can with the given power, since both the RNPP and the fan are variable.
Yeah, it's unfortunate that it doesn't work that way. And even if it did, you wouldn't be able to lower the fan speed without overtaxing the resistive fan controller. Best to switch back to a lower-current fan like the Noctua or the stock fan.
Why'd you switch from the Noctua to the Noiseblocker in the first place? It wasn't clear to me from your initial post in this thread.
Message 4 of 8
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-29
10:34 PM
2013-06-29
10:34 PM
I needed more case cooling as my temps were crossing the 65*C threshold, I live in a hot climate and having 33* ambient temps is not unusual. While I'm using an air cooler in the room (cannot run the aircon 24/7), I needed a bit more cooling in the RNPP case.
I haven't had a chance to look inside the RNPP, does the Power Supply have a spare 4-pin Molex? That would do the job for me, since I have a 4pin-3pin adapter already, or at most could source it quite easily.
Message 5 of 8
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-30
10:48 AM
2013-06-30
10:48 AM
RNPP PSU-->Molex (female)-->Molex (male)-->Molex (female)-->Molex (male) on RNPP M.Board to power HDDs
................................................... | <2 outputs>
................................................... -->Yellow/Black 12v cable-->Black Header-->3 pin NoiseBlocker Fan plug
Layout: http://i.imgur.com/IeoKeJl.jpg
Cables: http://i.imgur.com/nNQXkwD.jpg I'll be using the Black / Yellow pair and its associated connector, as described above.
RNPP Motherboard/Power Input: http://i.imgur.com/JsRab4R.jpg
My concern lies in that I'll be going from a 2 pin to a 3pin, hence I will be making the assumption that Yellow-->Red, Black to Black, White will have no connection. White is the Signal connection.
Just to clarify, I'm using the Yellow/Black pair from the Molex because thats the 12v side of the plug. The Black/Red is typically the 5v side.
Message 6 of 8
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-06-30
01:04 PM
2013-06-30
01:04 PM
Yeah so, apparently I didn't have to cut or splice or solder or anything. Not that I'm good at it...
http://i.imgur.com/BQDrKhH.jpg
And I'm a happy camper.
Will post before and after temps once it runs in a bit.
Message 7 of 8
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-07-01
10:01 AM
2013-07-01
10:01 AM
Noctua NF-P12
In all fairness, the new setup ought to run a bit warmer due to the change in position of the NAS, but can't argue with results! (So long as they're accurate).
Message 8 of 8
