Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
SeaTools
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-02-21
12:56 PM
2015-02-21
12:56 PM
SeaTools
Darn...I wish there was a way to run Seagate's SeaTools diagnostic on all of my readyNAS drives without having to pull them and hook them up one by one 😞
I'm getting a lot of reallocated sector counts on a specific drive in my Pro6 and it appears to be headed to that land of broken drives in the near future. Unfortunately, Seagate doesn't believe any diagnostic reports other than one from their own utility- go figure!
Message 1 of 16
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-02-21
01:10 PM
2015-02-21
01:10 PM
Re: SeaTools
You can return drives w/o running their utility. http://www.seagate.com/staticfiles/supp ... codes.html
Message 2 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-02-21
02:15 PM
2015-02-21
02:15 PM
Re: SeaTools
Thanks- I assume I'd report RAID system blocked SeaTools from testing the drive ?
Message 3 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-02-21
03:22 PM
2015-02-21
03:22 PM
Re: SeaTools
Or "Failed other diagnostic tools, I'm confident it is a bad drive" I've used that code in the past, and never had a problem.
Message 4 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-03-16
02:10 PM
2015-03-16
02:10 PM
Re: SeaTools
So now this drive has completely failed and though I've replaced it with some new drives, I'd love to get it swapped out at Seagate since it is still under warranty. They should replace it, but I'm wondering about the data on it- that is, if they replace it and keep this one, then later repair it, have I just given them a copy of all my data? I doubt they'd be too interested in going through it all, but just sayin I think I'd prefer that it was totally wiped and/or destroyed. Thoughts?
Message 5 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-03-16
05:35 PM
2015-03-16
05:35 PM
Re: SeaTools
How many disks do you have installed and what RAID level? If you have say three disks in RAID-5 they'd need two of your disks to be able to get your data. One disk is not enough.
Even if they do get enough disks at once, the disks likely have issues, so cloning may be required and some familiarity with Linux, software RAID, LVM, EXT4 etc. If cloning fails then attempts to get at your data would be much more time consuming again and require a different set of skills.
Message 6 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-03-16
06:59 PM
2015-03-16
06:59 PM
Re: SeaTools
Had 3, 1T drives in RAID (2 Volume set), so I think I'm probably good. Thanks for the explanation!
I just ordered 3 more 1T drives to add to this pro6 and then, when I get my failed drive warrantied back, I'll have 6, 1T drives!
Should be good at that point for sure!
Message 7 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-03-19
05:12 PM
2015-03-19
05:12 PM
Re: SeaTools
OK - drives are now here and I'm ready to install them, but I'm noticing quite a bit of internal dust in my Pro6. Any thoughts on cleaning it up? I'm wondering if compressed air would cause more trouble than it's worth or if it would be a good idea to give it a good blasting?? Thoughts??! Thanks!
Message 8 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-03-19
05:16 PM
2015-03-19
05:16 PM
Re: SeaTools
fastfwd wrote:
Best way to clean the NAS is to shut it down, open the case, and use a can of compressed air to blow the dust out of the fans and heatsinks (and out of the power supply, and from between the drives, and off the mesh on the front-panel door, etc.). Hold the fan blades still while you're cleaning them; the fan bearings can't withstand high RPMs and will fail if you spin them up with the compressed air.
Message 9 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-03-19
06:18 PM
2015-03-19
06:18 PM
Re: SeaTools
Thanks! I'll crank up the compressor tomorrow morning and give it a good blast (while holding the fan blades of course!).
Message 10 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-03-20
08:36 AM
2015-03-20
08:36 AM
Re: SeaTools
OK- so I blasted all the dust out of / off of it, and loaded my new disks into the Pro6. Previously, I had a 2 volume set spread across 3, 1T drives. I hope that I haven't made a mistake, but I ended up purchasing 3 new, 1T drives- figuring that I had 3, one went bad but will be warranty replaced in the near future, so while I'm waiting for that I'll just finish off the set with 3 more, 1T drives. That is to say, I now have 5, 1T drives and am waiting on the 6th to be replaced by Seagate. Upon bootup, my Pro6 noticed that I now have 5 drives, but it is proceeding with resync on disk #3 only (disks 4 + 5 are not really being utilized as of yet). Do I need to pull disks 4+5 once the resync is completed and then add them into the mix one at a time, or ?
Thanks
Thanks
Message 11 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-03-20
12:09 PM
2015-03-20
12:09 PM
Re: SeaTools
I think you can just wait, though my practice is to add one drive at a time (or factory reset with all in place).
Message 12 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-03-20
12:53 PM
2015-03-20
12:53 PM
Re: SeaTools
It finished resync onto the 3rd disk, so it basically re-created what was there before the disk failed, and now it is doing something called "restriping" which I assume means it is expanding the volumes up to max capacity with all 5 drives.
Message 13 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-03-20
07:11 PM
2015-03-20
07:11 PM
Re: SeaTools
So the "restriping" was to expand the volume onto the 4th disk. Once that finished, it then began the process all over again to "restripe" the entire 2 volume set out through 5 disks. Currently finishing that up now.
Message 14 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-03-21
05:15 AM
2015-03-21
05:15 AM
Re: SeaTools
All back to normal now with Raid2 over 5, 1T disks.
Message 15 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-03-21
06:42 AM
