× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Simple Connection Question
bruceread
I have a new ReadyNAS RN10200 and have a simple connection question.  My computers connect to the internet through a mobile hotspot on my cell phone, so I have no physical router to which to connect the ReadyNAS.  What's the best way to connect?  Seems that when I use an ethernet cable it disrupts the wireless connection to my hotspot.
Thanks!
Bruce
Message 1 of 5
vandermerwe
Master
Re: Simple Connection Question
The readynas must connect via Ethernet to something.
Does the mobile hotspot (gateway) have an IP address as on a LAN?  and are the computers connecting to it via a wireless LAN that the mobile hotspot creates?
If this is the case I think you will need to connect the nas to an access point of some sort then incorporate the AP into the LAN.
You could, as I think you have tried, connect direct to a PC, This will limit the functionality of the nas though as it will not be a LAN device and won't have an Internet connection.
Message 2 of 5
Guru
You can get a WiFi extender (or use a WiFi router in bridge mode).  That will let you connect the NAS via ethernet.
Message 3 of 5
bruceread
Thanks!  And if I connect to a bridge via ethernet, will that disable the computer's wifi connection to the mobile hotspot?  I have a bridge and seems that I tried that but then had a problem with the wifi.
Bruce
Message 4 of 5
Guru
Bruce
Your hotspot should see the extender as another client.  So it should not affect your computer's wifi connection.  There may be an issue with the specific bridge/hot spot combination you are using though.
Were you getting internet from the ethernet connection?
Message 5 of 5
Discussion stats
  • 4 replies
  • 3841 views
  • 0 kudos
  • 3 in conversation
Announcements
