× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
USB ver ?
stgeorge
Guide
USB ver ?
Can anyone help me identify which USB format the front "Backup" USB port is configured to on both a Pro6 and on an older Duo ?
Thanks
Message 1 of 4
Guru
Re: USB ver ?
Do you mean disk format? The port itself has no format.
Message 2 of 4
stgeorge
Guide
Re: USB ver ?
OK- options might be USB 1.1 or USB 2.0 or USB 3.0 (SS) or USB 3.1 (SS+)
Message 3 of 4
Guru
Re: USB ver ?
All USB ports on the pro6 and the duo v1 are USB 2.0. And their actual performance with USB 2.0 drives is slower than a normal PC.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3419 views
  • 0 kudos
  • 2 in conversation
Announcements
