× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Ultra 4 Plus - Memory Upgrade
Impulse007
I am still running a Ultra 4 Plus and I'm looking to upgrade the memory from the 1 GB stock. From what little information I can find the Ultra 4 Plus uses DDR2 memory but I'm unclear if the maximum amount of memory supported is 2 GB or 4 GB. Do anybody know? Also, is there a specific memory model number I should look for, etc?
Thanks,
Matt
Model: ReadyNAS RNDP400U|ReadyNAS Ultra 4 Plus Chassis only
Message 1 of 3
Marc_V
NETGEAR Employee Retired
Re: Ultra 4 Plus - Memory Upgrade
Hi @Impulse007
Here's a thread regarding advice on upgrading Memory.
As mentioned, Ultra 4 plus is not supported anymore so you need to keep the old RAM in case of any issues you may encounter.
Hope this helps!
Regards
Message 2 of 3
Marc_V
Hi @Impulse007
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Message 3 of 3
Discussion stats
  • 2 replies
  • 1376 views
  • 0 kudos
  • 2 in conversation
Announcements
