- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Ultra 6 Memory Upgrade Verification
- Mark as New
- Bookmark
- Subscribe
- Permalink
I want to upgrade the memory on my Ultra 6s. I have two. 8GB seems a little pricey so 4B will have tp do. I've searched the forum and want to verify which memory is correct for the Ultra 6. Can someone verify for me before I order?
Also does the Ultra 6 hold one or two memory sticks?
G.SKILL 4GB (2 x 2GB) 240-Pin SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory F2-6400CL5D-4GBNT
Patriot Signature Line 4GB (2x2GB) DDR2 800 PC2 6400 Memory Module Kit PSD24G800K
Crucial 4GB Kit (2GBx2) DDR2 800MHz (PC2-6400) CL6 Unbuffered UDIMM 240-Pin Desktop Memory
CT2KIT25664AA800 / CT2CP25664AA800
Which is/are correct? (If any!)
Thanks,
Dave-
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here you are. It is the ReadyNAS Ultra 6 (Not Ultra 6 Plus), the CPU is the Intel Atom D510. 2x2Gb
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ultra 6 Memory Upgrade Verification
I didn't even see this thread which I believe answers my question.
Not used to the new forum layout.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry. That does not answer my question. I thought mgdm's reply verified the question as to what type. It doesn't.
What type of memory do I need for my Ultra 6?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not sure that previous post does answer my question.
I'd appreciated verification of what memory I need. I hate returns.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That'
Well, when I upgraded my pro-6 a while back I went with Patriot Signature Line 8GB DDR2 800 PC2 6400 Memory Module PSD28G800K That's been in place for about a year, and I haven't run into any issues.
Though I don't know if that will work out as well on your ultra (and it is 2x4GB, not 2x2GB).
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Stephen, thanks. So many legacy models I'm just not sure. Ditto on memory. Too many choices. If I weren't ordering online it wouldn't be a big deal for a return.
sotrack, I'd appreciate that. Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Make sure it is a ReadyNAS Ultra 6 (Not Ultra 6 Plus), The CPU in the Ultra 6 is the Intel Atom D510:
http://ark.intel.com/products/43098/Intel-Atom-Processor-D510-1M-Cache-1_66-GHz
It has two DIMM (Not SODIMM) slots, supports up to maximum of 4GB (2GB each slot DDR2 667/800). Default was 1GB
The Ultra 6 (RNDU6000) and Ultra 6 Plus (RNDP600U) have very different hardware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi mdgm,
It's an Ultra 6 not Ultra 6 Plus.
From Frontview:
Model: | ReadyNAS Ultra 6 [X-RAID2] |
Serial: | 2EE107R60017D |
Firmware: | RAIDiator 4.2.27 |
Memory: | 1024 MB [DDR2] |
That's one of the things that's confusing. The photos on the early Ultra user guides and the website show a picture of the NV series.
In my seraching I checked Hardware Compalibility for memory and got "Page Not Found".
http://kb.netgear.com/app/error//error_id/1
Saw Stephen's posts about the Pro 6. Saw posts about the Ultra 6 Plus.
I could go on but I'll stop. 🙂
I'm just a tad bit confused and need some verification. Any clarification is helpful.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The specs I mentioned are for the Ultra 6.
sotrack's example of what he used will be helpful too.
After replacing the memory you should run at least a couple of passes of the memory test. N.B. it is possible that incompatible memory may pass the memory test.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an Ultra 6 too.
Recently I have added an extra 1 GB PC2-6400.
Just in case OS6 would require more.
So I have 2 GB know, that seems to be enough in my situation.
- Mark as New
- Bookmark
- Subscribe
- Permalink
sotrack, that's the ticket!
Thanks. I've ordered 2 sets for both my Uttras.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Jan, thanks for your reply.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Memory rec'd and memory test running on first unit.
For the life of me I could not remove the motherboard. after taking out the 6 screws I was having to apply too much force.
Thankfully, I have small hands and was able to snap the memory in.
I have one more unit to do assuming things go well with unit 1.
Any tips on removing the mobo?
Will report success or failure. Thanks for all the help esp. sotrack's pic.
- Mark as New
- Bookmark
- Subscribe
- Permalink
6 is not enough. I recall removing 1 or 2 screws from the back as well. Near the USB or network connector.
Then you have to gently pull it a bit away from the back (couple of millimeters) before trying to move it up.
Near the spot where you removed 4 screws is a large connector that connects this part of the board to another board.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Jan, I removed two screws from the read to slide off the side plate. Then I removed 6 screws from the mobo. (See sotracks' picture). After that I tried to gently pull the mobo away from the USB/ethernet side but it seemed much to tight to pull any further.
- Mark as New
- Bookmark
- Subscribe
- Permalink
To remove the motherboard after you have removed the side, there is still 1 screw to be removed,
There are 2 USB connections and another connection I do not recognize.
Above that other connection there is a screw you have to remove to.
When you look at sotrack's picture you see a small almost cubicle component on that location.
That is there to hold the screw.
(sorry for my dunglish)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Jan, I will take another look. I believe I removed that screw as well.
Your Dunglish is just fine, my friend. 🙂
