- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Upgrade from 6.9.1 to 6.10 hangs
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi.
In my RN528X I had installed the firmware 6.9.5 patch 1 release and I downloaded and installed version 6.10.0. But at the time of the reboot after the upgrade the boot reaches 99% and then it doesn't go on and it doesn't finish. The display shows "Booting ....
What can it have happened and how can I solve it?
Thanks in advance.
/Sören
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Upgrade from 6.9.1 to 6.10 hangs
RN528X, more info. I tryed to do it first and i come back to 6.9.1 fix so I tried one mor time and after that it hangs in "Booting..."
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
How to do that? There is no IP-address so I have no access to the NAS any more.
/Sören
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
Not sure if this will help but I had this identical problem today with a 204 unit. I had rebooted prior to the update and still it sat stuck for an hour at 99%. Multiple reboots failed to solve it and I was only semi-sure I had a valid backup.
In the end I found the bootmenu option -
For 104,204,214,314 - https://kb.netgear.com/22891/How-do-I-access-the-boot-menu-on-my-ReadyNAS-104-204-214-or-314
And 528X, 628X - https://kb.netgear.com/000036944/How-do-I-access-the-boot-menu-on-my-ReadyNAS-528X-and-628X
I was ready to factory reset but instead did OS-Reinstall - big sigh, it rebooted and took a little longer but came up fine.
Once back on volumes all online, but had to redo network settings and admin password was defaulted.
Not sure but it might help in your case.
Mark
- Mark as New
- Bookmark
- Subscribe
- Permalink
In similar cases there often is an IP address and the logs can be downloaded. So maybe download RAIDar, and see if it can discover your NAS.
- Mark as New
- Bookmark
- Subscribe
- Permalink
after redynas 312 rebooted to update never came back on i got only flashing power button i thought that update would be tested
before release thax netgear anyone knows how to recover without loosing data ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry, there is no connection with my RN528X and still in "Booting..." position.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, I tried RAIDar but there is no connection/or find my RN528X. 😞
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry to inform but I fowlloing the instruction but nerver get "boot menu message". Even if I hold the reset buttom in for two minutes the display just show "Booting..."
- Mark as New
- Bookmark
- Subscribe
- Permalink
Now I tried to remov all 8 disks and boot the system and press the reaset butom when power the NAS on. Still after two minutes the Displa shows "Booting..." and the blue LED on the front turns off. Now I think after reading that som other person have the same type of experiance as I have that NETGEAR has a real problem with the new 6.10 when trying to upgrade from 5.9.1 😞
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well, the system can't boot with no disks, because the system boots from the disks.
6.9.1?
I upgraded three systems from 6.9.5 to 6.10.0 with no issue. While it's possible that there is something broken on the 6.9.1->6.10.0 upgrade path, I think it is more likely that something in your specific system misbehaved during the upgrade.
Your best option is to use paid support (my.netgear.com).
- Mark as New
- Bookmark
- Subscribe
- Permalink
With my unit, the disks were left in place; not removed. Unit was powered off by removing power lead from rear (power button not doing anything useful like turning it off).
Held in reset button with small paperclip, then whilst holding reset (tricky), reinserted power lead and then pushed and held both power and reset button till boot menu appeared. Then released both power and reset button.
Pushed backup button on front and selected "OS-Install" and click pressed reset again to select.
Left to boot and my unit was sorted.
I agree it does sound like some issue with the update as my box was perfectly fine before.
- Mark as New
- Bookmark
- Subscribe
- Permalink
FYI - my box was running 6.9.5 prior to the update. Only errors I could find in the logs I pulled after recovery pointed to issues with mysql-server and Plex media server. So maybe interaction with the update and certain apps??
Got two more NAS boxes to update next week, think I might wait a little while now and make sure those backups are 100%
- Mark as New
- Bookmark
- Subscribe
- Permalink
Always a good strategy before updating firmware.
That is interesting, and might be a clue. Can you post a snippet of those issues?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Stephen,
Just out of interest did you deploy the update by manually downloading or allow the box to update itself?
Plex error might just be a red herring.
Maybe I am wrong (probably), but it looks like it updated to 6.10.0 first, rebooted, then tried to automatically get 6.10.+Hotfix2 and then came unstuck; which I note there is now an option in Settings for installing "Automatic Hotfix Updates" enabled by default, don't recall seeing that before.
Between the first update/auto reboot and getting stuck was about 40 minutes (it seemed like an hour, but logs don't lie) before I thought something was amiss.
Here is some info:-
ReadyNAS 204
Timeline - (UK BST) 24/04/2019.
13:27 - Unit rebooted to flush caches etc. prior to update (should have double checked backup as well!!)
13:29 - Unit operational after reboot
13:31 - Allowed update to 6.10.0 to install (from 6.9.5)
- Period of downtime, unit reboots and sits at 99%, with "Booting", power button toggles text to "msql.service", all disk activity noise stops. RAIDar shows device as "Starting up" but cannot access.
- Unit inaccessible from Management page or thru volume shares. Can ping device only. No SSH access.
14:10ish- Attempted manual intervention - unable to shutdown, removed power.
15:26 - Unit back in operation after OS-Reinstall (from Boot menu) ;due to failed boot attempts (and pulling power), disk drives needed resync for Raid
15:39 - Removed unneeded Plex Media App (for RN2xx)
21:36 - Raid Resynced - Unit fully operational, no visible issues.
Then seeing these events occured each time before "stuck" at 99% with Booting/msql.service on screen.
SYSTEM.LOG
Apr 24 14:15:15 NETGEARNAS /etc/mysql/debian-start[3003]: Upgrading MySQL tables if necessary.
Apr 24 14:15:15 NETGEARNAS /etc/mysql/debian-start[3006]: /usr/bin/mysql_upgrade: the '--basedir' option is always ignored
Apr 24 14:15:15 NETGEARNAS /etc/mysql/debian-start[3006]: Looking for 'mysql' as: /usr/bin/mysql
Apr 24 14:15:15 NETGEARNAS /etc/mysql/debian-start[3006]: Looking for 'mysqlcheck' as: /usr/bin/mysqlcheck
Apr 24 14:15:15 NETGEARNAS /etc/mysql/debian-start[3006]: This installation of MySQL is already upgraded to 5.5.53, use --force if you still need to run mysql_upgrade
Apr 24 14:15:15 NETGEARNAS /etc/mysql/debian-start[3017]: Checking for insecure root accounts.
Apr 24 14:15:15 NETGEARNAS /etc/mysql/debian-start[3022]: WARNING: mysql.user contains 4 root accounts without password!
Apr 24 14:15:16 NETGEARNAS nmbd[2153]: [2019/04/24 14:15:16.031191, 0] ../lib/util/become_daemon.c:138(daemon_ready)
Apr 24 14:15:16 NETGEARNAS nmbd[2153]: daemon_ready: STATUS=daemon 'nmbd' finished starting up and ready to serve connections
Apr 24 14:15:16 NETGEARNAS /etc/mysql/debian-start[3023]: Triggering myisam-recover for all MyISAM tables
Apr 24 14:15:17 NETGEARNAS afpd[2524]: Netatalk AFP/TCP listening on 192.168.2.8:548
Apr 24 14:15:39 NETGEARNAS nmbd[2153]: [2019/04/24 14:15:39.300414, 0] ../source3/nmbd/nmbd_become_lmb.c:397(become_local_master_stage2)
Apr 24 14:15:39 NETGEARNAS nmbd[2153]: ***** Samba name server NETGEARNAS is now a local master browser for workgroup WORKGROUP on subnet 192.168.2.8 *****
Apr 24 14:17:02 NETGEARNAS CRON[3141]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 24 14:17:02 NETGEARNAS CRON[3142]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Apr 24 14:17:02 NETGEARNAS CRON[3141]: pam_unix(cron:session): session closed for user root
Apr 24 14:18:37 NETGEARNAS libapache2-mod-php5[3279]: php5_invoke opcache: already enabled for apache2 SAPI
Apr 24 14:18:37 NETGEARNAS libapache2-mod-php5[3305]: php5_invoke xcache: already enabled for apache2 SAPI
Apr 24 14:18:37 NETGEARNAS libapache2-mod-php5[3331]: php5_invoke gd: already enabled for apache2 SAPI
Apr 24 14:18:38 NETGEARNAS libapache2-mod-php5[3357]: php5_invoke pdo_mysql: already enabled for apache2 SAPI
Apr 24 14:18:38 NETGEARNAS libapache2-mod-php5[3383]: php5_invoke pdo: already enabled for apache2 SAPI
Apr 24 14:18:38 NETGEARNAS libapache2-mod-php5[3409]: php5_invoke mysqli: already enabled for apache2 SAPI
Apr 24 14:18:38 NETGEARNAS libapache2-mod-php5[3435]: php5_invoke json: already enabled for apache2 SAPI
Apr 24 14:18:38 NETGEARNAS libapache2-mod-php5[3461]: php5_invoke mysql: already enabled for apache2 SAPI
Apr 24 14:18:39 NETGEARNAS libapache2-mod-php5[3484]: apache2_invoke php5: already enabled
-- Reboot --
SYSTEMMD.LOG
Apr 24 14:16:49 NETGEARNAS systemd[1]: Starting ReadyNAS Update...
Apr 24 14:17:00 NETGEARNAS readynas-upgrade[2513]: W: Failed to fetch https://apt.readynas.com/packages/readynasos/dists/6.10.0/InRelease Could not resolve host: apt.readynas.com
Apr 24 14:17:00 NETGEARNAS readynas-upgrade[2513]: W: Failed to fetch http://mirrors.kernel.org/debian/dists/jessie/InRelease Could not resolve 'mirrors.kernel.org'
Apr 24 14:17:00 NETGEARNAS readynas-upgrade[2513]: W: Failed to fetch http://security.debian.org/dists/jessie/updates/InRelease Could not resolve 'security.debian.org'
Apr 24 14:17:00 NETGEARNAS readynas-upgrade[2513]: W: Some index files failed to download. They have been ignored, or old ones used instead.
Apr 24 14:18:35 NETGEARNAS readynas-upgrade[2513]: Setting up libapache2-mod-php5 (5.6.40+dfsg-0+deb8u2) ...
Apr 24 14:18:39 NETGEARNAS readynas-upgrade[2513]: apache2_invoke php5: already enabled
Apr 24 14:18:40 NETGEARNAS systemd[1]: Reloading.
Apr 24 14:18:40 NETGEARNAS systemd[1]: [/lib/systemd/system/fvapp-plexmediaserver-annapurna.service:11] Invalid escape sequences in line, correcting: "/bin/sh -c '/apps/plexmediaserver-annapurna/Binaries/Plex\ Media\ Server'"
Apr 24 14:18:40 NETGEARNAS systemd[1]: systemd-journald-audit.socket: Cannot add dependency job, ignoring: Unit systemd-journald-audit.socket is masked.
Apr 24 14:18:42 NETGEARNAS rn-update.sh[3124]: W: Failed to fetch https://apt.readynas.com/packages/readynasos/dists/6.10.0/InRelease Could not resolve host: apt.readynas.com
Apr 24 14:18:42 NETGEARNAS rn-update.sh[3124]: W: Failed to fetch http://mirrors.kernel.org/debian/dists/jessie/InRelease Could not resolve 'mirrors.kernel.org'
Apr 24 14:18:42 NETGEARNAS rn-update.sh[3124]: W: Failed to fetch http://security.debian.org/dists/jessie/updates/InRelease Could not resolve 'security.debian.org'
Apr 24 14:18:42 NETGEARNAS rn-update.sh[3124]: W: Some index files failed to download. They have been ignored, or old ones used instead.
Apr 24 14:28:50 NETGEARNAS systemd[1]: Starting Cleanup of Temporary Directories...
Apr 24 14:28:50 NETGEARNAS systemd[1]: Started Cleanup of Temporary Directories.
Apr 24 14:32:24 NETGEARNAS systemd-logind[2016]: Power key pressed.
-- Reboot --
And then this
[2019/04/24 12:34:10 UTC] Updated from ReadyNASOS 6.9.5 (ReadyNASOS) to 6.10.0 (ReadyNASOS).
[2019/04/24 14:25:02 UTC] Updated from ReadyNASOS 6.10.0 (ReadyNASOS) to 6.10.0 (ReadyNASOS).
- Mark as New
- Bookmark
- Subscribe
- Permalink
I manually installed it.
@Markwig wrote:Could not resolve host: apt.readynas.com
These should have resolved, and might be part of the problem. Perhaps ask @JohnCM_S or @OOM-9 if they are willing to review the full log zip file. Don't post a link here, as there is information in the logs that shouldn't be posted publicly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Markwig My RN528X has been working well unitll i tried to do the upgrade from 6.9.5 to 6.10. No I have a NAS that is more or less dead. So fare it always end with "Booting..."
Do Yoy know if its possible to reinstall via the USB port?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@StephenB sorry. Misstyping. I whent from 6.9.5 to 6.10.0. I did it from the NAS. After first try and a reboot it still said that the unit had 6.9.5. So I tried one more time to upgrade to 6.10.0. Then I always end up att "Booting...". I have tried to follow instructions to get to the Boot Meny but I never get there.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Soren,
Bit puzzling why you cannot seem to get the boot menu, as the option to "factory reset" is also there if needed. Did you leave the disks in when you tried? As StephenB said "the system boots from the disks" and they are needed so the unit can copy across the OS from its internal memory onto the disks and replace any corrupt OS files; leaving the data intact.
Please do not assume I am an expert on these units; there are far more qualified people than me on this forum.
Here is a link to the USB reinstall method if that helps - https://kb.netgear.com/29952/How-do-I-use-the-USB-Recovery-Tool-on-my-ReadyNAS-OS-6-storage-system
But if your data is vital and you are unsure then I would urge you to seek guidance from Netgear on this before implementing; I did an OS reinstall as I was prepared to accept the loss and revert to backups, and buy a new unit if really needed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are you following the instructions on pages 146-147 here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf
- Mark as New
- Bookmark
- Subscribe
- Permalink
mine to after os reinstall it booted ok with new upgraded firmware with hot fix apllied at the end
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @SorenB,
If you are still stuck on 'Booting...' even when trying you access the boot menu, you can hook up a console cable to the NAS so we can check what it says and advise how to fix. You may provide to me the console logs via PM (private message).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I do.
/Sören
