× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Using a solid state in RN21400
Bjohn1
Hi Folks,
I have a RN21400 with 2, 2tb HDDs.
One of the disks is getting a high uncorrectable error count, so needs replacing.
May I replace it with a solid state drive, are these compatible?
If so, any suggestions/ links on which I could use.
(I have searched forum, couple of similiar questions but I cant even understand the answers)
Any comments gratefully recived.
Kin Regards
Model: RN21400|ReadyNAS 214 Series 4- Bay (Diskless)
Message 1 of 2
Accepted Solutions
Guru
Re: Using a solid state in RN21400
If the size matches, then you can use it.  But you won't get SSD speed unless you replace both drives.  Likely you will get a warning about a speed mismatch.
FWIW, the HCL only lists Samsung 850 Pro and Samsung 860 Pro models in this size range.  The 860 pro is expensive, I don't think the 850 pro is still available in this particular size.  Other SSDs likely will work, but at least some of them misbehave in minor ways.  For instance: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/rn-expand-2065-Failed-to-get-device...
Message 2 of 2
All Replies
Guru
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 727 views
  • 1 kudo
  • 2 in conversation
Announcements
