× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
WD Red Pro WD2002FFSX 2TB on ReadyNAS 3200
bachtech
I have a client with a ReadyNAS 3200 v1 running RAIDiator 4.2.27, and 12x 1TB drives in X-RAID2. From what I understand this NAS only supports up to 2TB drives in all bays (that said I *believe* 1-4 are 3TB+), so I would like to replace all drives with 2TB drives. My questions are:
1. Are WD WD2002FFSX drives compatible? The compatibility list seems to be out of date, though I have installed reds in a ReadyNAS 2100 and it worked fine.
2. How much usable space will I have in a X-RAID2? 18TB?
Thanks!
Model: RN12P|READYNAS 3200 NETWORK STORAGE SYSTEM - CHASSIS|EOL
Message 1 of 3
Accepted Solutions
Sandshark
Sensei
Re: WD Red Pro WD2002FFSX 2TB on ReadyNAS 3200
Yes, they are compatible.  WD even suggests them for NASes up to 16 bays,  You will get 18TB with a 12 drive volume with dual redundancy RAID6 (XRAID or not) or with 2 x 6 drive Raid 5 volumes.  If you are running RAIDiator 4.2.x, you cannot grow the volume to that size, you have to factory default with the drives in place.  For that reason, you may want to consider updating to OS6, for which you also need to factory default.  With OS6, you could later upgrade the first 4 drives to grow an XRAID volume.
Message 2 of 3
All Replies
Sandshark
Sensei
Message 2 of 3
bachtech
Great, thanks for the info!
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2924 views
  • 1 kudo
  • 2 in conversation
Announcements
