× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
WD Red drives park their heads like WD Green drives?
Messerschmitt
Re: WD Red drives park their heads like WD Green drives?
Which one is that and what does it do
Message 51 of 72
Guru
http://support.wd.com/product/download.asp?groupid=619&sid=201&lang=en
It is their supported tool for changing the head parking threshold. wdidle is quite old.
Message 52 of 72
Messerschmitt
Does this only change the parking threshold? I thought WDIDLE3 disables it to begin with... It also mentions that you should do a backup, and it seems it's not a DOS program?
Message 53 of 72
Guru
WDIDLE3 is an old program, and WDC says it isn't compatible with all their drives. The new program is what they want you to use, and they've gone to the trouble to provide windows, mac, and linux versions.
I don't know why you'd want a DOS program, but feel free to use whatever. HDPARM also apparently can be used.
Message 54 of 72
portucale
Good news everyone!!!
I just bought 2 WD30EFRX-68EUZN0 and after reading the reported problem because of LLC 8 seconds, i decided to check the default disk values.
CONGRATULATIONS TO YOU ALL!
WD changed the value from 8 to 300 seconds because of YOUR CLAIMS, giving you reason!
(just to mention that the disk date is january 2014)
Entering in ssh ReadyNAS102 i run ....
root@HOME_NAS:/# hdparm -J /dev/sdb
/dev/sdb:
wdidle3 = 300 secs (or 13.8 secs for older drives)
et voilá
if someone want's more info's about my disks, fill free to ask! it's possible that other value have been changed...
Meanwhile here is the result of running smartctl -a /dev/sda
root@HOME_NAS:/# smartctl -a /dev/sda
smartctl 6.1 2013-03-16 r3800 [armv7l-linux-3.0.101.RN_ARM.1] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Western Digital Red (AF)
Device Model: WDC WD30EFRX-68EUZN0
Serial Number: ???????
LU WWN Device Id: ????????
Firmware Version: 80.00A80
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 5400 rpm
Device is: In smartctl database [for details use: -P show]
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 1.5 Gb/s)
Local Time is: Tue Mar 11 22:25:41 2014 WET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: (44220) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 443) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 100 253 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 100 253 021 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 1
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 0
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 1
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 0
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 0
194 Temperature_Celsius 0x0022 121 121 000 Old_age Always - 29
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Message 55 of 72
letsgowithbob
I just purchased the WD red 4TB drives, and then found this thread. I was terrified I had bought the wrong drives, and that these WD red's would not last very long. I had two Seagate Barracuda 3TB drives fail on me at 9, and 10 months respectively.
I looked at all the fixes presented so far, but wanted to give the drives a chance with no modifications. My drive has been in my Netgear NAS ultra 2 for 24 hours now with an LCC count of 0. I am getting this information from the smart button on the drive
Model: WDC WD40EFRX-68WT0N0
Serial: WD-WCC4E1126755
Firmware: 80.00A80
SMART Attribute
Raw Read Error Rate 0
Spin Up Time 0
Start Stop Count 2
Reallocated Sector Count 0
Seek Error Rate 0
Power On Hours 27
Spin Retry Count 0
Calibration Retry Count 0
Power Cycle Count 2
Power-Off Retract Count 1
Load Cycle Count 0
Temperature Celsius 42
Reallocated Event Count 0
Current Pending Sector 0
Offline Uncorrectable 0
UDMA CRC Error Count 0
Multi Zone Error Rate 0
ATA Error Count 0
I believe this means that my LCC is not being affected as in previous drives, Can someone let me know. Is there a more in depth test I should run to verify these results?
Message 56 of 72
Guru
Since your load cycle count is zero, you are fine.
Message 57 of 72
shedz
I've just purchased a readynas 312 and 2 x 3TB WD red drives. Would you like me to test idle times (load cycles)? Would have to figure out how to do this though.
Message 58 of 72
Guru
All you need to do is look at the SMART stats. Download the logs, and then download them again a day later, and compare the load cycle counts in disk_info.log
But letsgowithbob should be fine - he'd have seen much higher counts if he had installed drives which had the too-short threshold.
Message 59 of 72
tony359
Apprentice
Hi there,
running idle3ctl on my NAS gives the following result for both my REDs
Idle3 timer set to 138 (0x8a)
I'm just curious, since my load count is 7 after 29 hours, but what does 138 means?
Message 60 of 72
Guru
I believe it means the head parking timer is set to 300 seconds on those drives. That is based on the info here: http://idle3-tools.sourceforge.net/
129 -> 30 seconds
130 -> 60 seconds
138 -> 300 seconds
Message 61 of 72
tony359
Apprentice
Cool, thanks, I did not reach the end of the page 🙂
Message 62 of 72
Supercows
Guide
Reading this articel, is it save to buy the 4 TB version WD for the ultra 2 or is it better to buy another disk ?
Message 63 of 72
Guru
It's not on the HCL, so netgear will likely deny support.
However, it will work. You should check the load-cycle counts after installation, and if they climb you can reset them with the WDC software tool. That is easiest if you temporarily connect the drive to a windows PC.
Message 64 of 72
tony359
Apprentice
I know it may be just a nonsense to justify why they're denying support, but I am told by support that 4TB RED are seen causing trouble on some units. I am also told they are being tested on OS6 machines now, and that for the time being there are no plans to test them on OS4 in the future.
I have those drives, and experienced ONE kernel crash on my unit. It may be relevant, it may be not, I just thought I should add it to the conversation.
Message 65 of 72
Retired_Member
Not applicable
I just confirm > I HAVE BOUGHT NEW WD RED 4TB today, i have checked default value by using guide from posts in this topic and IT IS SET BY DEFAULT TO 300.
Message 66 of 72
portucale
After 80 days (24/7) my 2 WD RED 3TB WD30EFRX-68EUZN0 have these values on a ReadyNAS102:
/dev/sda
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 217 179 021 Pre-fail Always - 4116
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 22
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 098 098 000 Old_age Always - 2004
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 22
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 16
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 5
194 Temperature_Celsius 0x0022 119 115 000 Old_age Always - 31
/dev/sdb
3 Spin_Up_Time 0x0027 204 178 021 Pre-fail Always - 4775
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 21
9 Power_On_Hours 0x0032 098 098 000 Old_age Always - 1997
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 21
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 15
194 Temperature_Celsius 0x0022 119 116 000 Old_age Always - 31
i think these values are good in terms of a NAS environment
Message 67 of 72
Guru
My oldest looks like this:
Spin Up Time 5650
Start Stop Count 349
Seek Error Rate 0
Power On Hours 15374
Spin Retry Count 0
Power Cycle Count 13
Power-Off Retract Count 7
Load Cycle Count 341
Temperature Celsius 31
ATA Error Count 0
Message 68 of 72
jerryk1
I just installed 2 WD Red 3 TB drives. The number look better than others, but should I be happy about these readings.
Drive 5
Firmware: 80.00A80
SMART Attribute
Spin Up Time 5116
Start Stop Count 81
Seek Error Rate 0
Power On Hours 320
Spin Retry Count 0
Power Cycle Count 8
Load Cycle Count 79
Temperature Celsius 38
ATA Error Count 0
Drive 6
Firmware: 80.00A80
SMART Attribute
Spin Up Time 5216
Start Stop Count 16
Seek Error Rate 0
Power On Hours 34
Spin Retry Count 0
Power Cycle Count 4
Load Cycle Count 14
Temperature Celsius 36
ATA Error Count 0
Message 69 of 72
Guru
The numbers look normal to me. It looks like you have disk spindown enabled. If so, what threshold are you using?
Is there something in particular you are concerned about?
Message 70 of 72
jerryk1
I have the spin down set for 10 minutes.
I just have a basic concerned based on some of the comments in this thread and on the internet in general about the Red drives. Seems like a number of people have had premature failures of the drives.
Message 71 of 72
Guru
That explains the high start/stop count. I don't see any problem leaving the threshold there. Personally I use longer thresholds (~60 minutes).
For a brief period a WDC firmware change reset the head parking threshold too low for the ReadyNAS - which resulted in rapidly rising load cycle counts. They have since fixed that (and provided a tool to allow people to adjust those thresholds themselves if needed).
If you had that issue, your load cycle counts would have been much higher.
I don't know about the "internet in general". I am running 8 of these drives in various NAS (a 2 TB model in a duo v1, 5 3 TB in a pro-6, and two 3 TB models in an RN102). The oldest has been running more than 15000 hours, several others are over 10000. The newest has about 2700. I've had no problems with any of them.
As far as I can tell from the posts here, NAS users are finding them to be quite reliable. Note that all drives have some failures, and people who have problems are more likely to post their experience than people who aren't having any.
Message 72 of 72
Top Contributors
Discussion stats
Announcements
