Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WD20EARS-00MVWB0 - works with NV+ or not?
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-02-01
09:57 PM
2011-02-01
09:57 PM
Could it be clarified if WD20EARS-00MVWB0 Western Digital hard drive is officially compatible with NV+?
This is the latest model which retailers stock at the moment. I doubt the approved one can actually be found, at least not here in Australia.
Cheers,
Steve
Cheers,
Steve
Message 1 of 22
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-02-01
10:43 PM
2011-02-01
10:43 PM
Re: WD20EARS-00MVWB0 - works with NV+ or not?
The magic 8-ball reveals: outlook uncertain
Message 2 of 22
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-02-07
03:56 AM
2011-02-07
03:56 AM
Yes. I would also love to know.
Just checked with the i-store today - they have WD20EARS-00MVWB0 which seams the latest model (manufactured January 2011), although there are reference on the web (http://vr-zone.com/articles/667gb-per-p ... 335-2.html) going back to July 2010!?
Reading that reference I am more inclind to get WD20EARS-00MVWB0 (if on HCL which seems to never be able to chatch up with drive manufacturers) - 3 platter drive may be more reliable and better perfoming.
I should add that I got my brand new NV+ four (empty) bays on 1/1/2011 with intentions to place 4x2GB WD drives, thinking any 2TB under 4.1.7 would be OK. It has been extremly frustrating experience for me to get my NV+ going.
In the process I managed to get the first two unit fail to boot at all after attempting to upgrade to 4.1.7 via TFTP and USB. I am having a bit more luck with the third unit - and imagine I've been in IT (somewhat different type) for many many years.
I never thought NV+ to be engineered to make life so hard - why would NV be so particular and precious about drives? cannot imagine having to do this kind of acrobatics placing any hard drive in any windows/linux pc? how difficult can the firmware process be? why this cannot be simply performed on the diskless unit (as I originally expected).
So far, I have an older 400GB drive installed, upgraded the unit to 4.1.7 installed additional HCL approved WD20EARS 00S8B1 to get usable just under 400GB across the two drives (as expected). I am unsure about the steps
Still not sure if am on on 512 or 4k sectors - is there a way to tell? I have done a factory default performed after upgrade via RAIDar/setup browser interface.
The plan is to get all 2TB drives and WD20EARS-00MVWB0 seems like a good choice.
It has been previously suggested that I am "fixated on WD".
<You seem to be fixated on the WD20EARS drives. Are these drives that you already have in hand?>
<If not, why not consider other makes/models? >
WD served me very well over many years, 100% reliable and at this stage, specially reading this forum, I believe I have considerable risk by introducing NV+ into the equasion.
Please understand I am really appreciative for advice provided on this forum ... as long as it's polite and not patronising -
zest
zest
Message 3 of 22
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-02-07
04:01 AM
2011-02-07
04:01 AM
Under Status > Logs > Download all logs > extract zip contents, what does your partition.log look like?
Message 4 of 22
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-02-07
04:48 AM
2011-02-07
04:48 AM
copy of my partition.log below
Disk /dev/hde doesn't contain a valid partition table
Disk /dev/hdc: 400.0 GB, 400077971456 bytes
255 heads, 63 sectors/track, 48640 cylinders, total 781402288 sectors
Units = sectors of 1 * 512 = 512 bytes
Disk identifier: 0x00000000
Device Boot Start End Blocks Id System
/dev/hdc1 32 4096031 2048000 83 Linux
Partition 1 does not end on cylinder boundary.
/dev/hdc2 4096032 4608031 256000 82 Linux swap / Solaris
Partition 2 does not end on cylinder boundary.
/dev/hdc3 4608032 781385935 388388952 5 Extended
/dev/hdc5 4608040 781385935 388388948 8e Linux LVM
Disk /dev/hde: 2000.3 GB, 2000388448256 bytes
255 heads, 63 sectors/track, 243200 cylinders, total 3907008688 sectors
many thanks for decifering ... looks like it's still 512? so would I move it to 4k?
zest
zest
Message 5 of 22
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-02-07
04:55 AM
2011-02-07
04:55 AM
You can see the start sectors (e.g. 32) are divisible by 8. It is aligned for 4k sectors. The tool just measures as if the sectors were 512 bytes.
Message 6 of 22
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-02-07
05:06 AM
2011-02-07
05:06 AM
so we all good. can I please ask you if the following approach is ok to insert more drives, having the 400GB and 2TB already in there -
1. insert another 2TB and sync
2. replace the 400GB with 2TB, (power down, remove 400GB, insert 2TB, power up, hope for the resync on the new 2TB)
3. inser the fourth 2TB to complete the set and resync
would you recommend any other action?
appreciate your expert addvice
... I might get to like my NV+
zest
zest
Message 7 of 22
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-02-07
05:07 AM
2011-02-07
05:07 AM
That should work fine. You could replace the 2TB drive first if you wish though.
Message 8 of 22
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-02-07
05:12 AM
2011-02-07
05:12 AM
many many thanks.
I'll report results back in a day or two
zest
zest
Message 9 of 22
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-02-07
10:42 PM
2011-02-07
10:42 PM
I don't know about the NV, but I can confirm the WD20EARS-OOMVWB0 does NOT work with the ReadyNAS Duo.
However it should be possible to use the jumper settings on the disk to alter it from 4k block to 512byte. Anyone tried this already?
Message 10 of 22
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-02-08
01:33 AM
2011-02-08
01:33 AM
I have just bought a NV+ which came supplied with firmware 4.1.6. I put the drives in and it all seemed to work fine.
The only problem I did encounter is when copying files from a win2k machine it would create a directory and then copy the file into it but report the share was longer available. It was as if after creating the directory it wasnt ready to be used immediately.
I wanted to upgrade to 4.1.7 anyway so I pulled the 2nd drive to stop the rebuild and then applied the firmware upgrade and let it boot afterwards. Then when I confirmed 4.1.7 was running I did a full factory reset and left it rebuilding overnight. This morning I started copying across 200GB from a usb drive using the win2k machine again without any problems.
Message 11 of 22
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-02-08
04:41 PM
2011-02-08
04:41 PM
gblades,
are you saying you have a 4 bay NV+ with WD20EARS-00MVWB0 (fully populated, eg 4 drives) and it all worked at rel 4.1.6?
I belive it is not supposed to work unless you get firmware up to 4.1.7.
I got mine upgraded to 4.1.7 using an older Seagate 400GB (HCL approved drive).
I then inserted another HCL approved drive HCL 2TB WD20EARS 00S8B1 - all synced well and as expected I got fully redundant 384GB across the two drives (equivalent to the smaller drive)
All well up to this point.
Last night while powered down I removed the 400GB Seagate and replaced it with 2TB WD20EARS-00MVWB0 -
so I had two bays with 2TB in each (WD20EARS-00MVWB0 + WD20EARS 00S8B1)
after a long re-sync process all seems fine BUT I only got 384GB volume across the two 2TB drives!
How do I extend it to full 2TB?
zest
zest
Message 12 of 22
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-02-08
04:46 PM
2011-02-08
04:46 PM
You're supposed to factory default after upgrading to 4.1.7 or you may have poor write performance using the WD20EARS. 4k sector alignment requires a factory default after updating to 4.1.7.
There's also the adding support for drives that don't support TLER in 4.1.7.
As for expanding your volume have you tried a reboot?
Message 13 of 22
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-02-09
01:21 AM
2011-02-09
01:21 AM
I only had 2 drives when it worked in 4.1.6.
The quickest way I found to upgrade to 4.1.7 with these drives is as follows and this is what I did after seeing that it was working in 4.1.6. I did this because of the fact it should have a factory reset after the 4.1.7 update
1) Put in 1 drive only and perform a factory reset.
2) As there is 1 drive after it boots there is no rebuild going on in the background so you can go straight ahead and install the update.
3) Let it reboot into 4.1.7 to make sure it has loaded ok.
4) Shutdown and fit the additional drives.
5) Perform a factory reset.
Message 14 of 22
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-02-14
01:12 AM
2011-02-14
01:12 AM
I need to report that after reboot my X-RAID picked up and expanded the second and third disk
so my current config is:
bay1: WD20EARS-00MVWB0
bay2: WD20EARS 00S8B1
bay3: WD20EARS-00MVWB0
bay4: WD20EARS-00MVWB0
634 GB (17%) of 3692 GB used
Ch 1 : WDC WD20EARS-00MVWB0 [1862 GB] 1859 GB allocated
Ch 2 : WDC WD20EARS-00S8B1 [1862 GB] 1859 GB allocated
Ch 3 : WDC WD20EARS-00MVWB0 [1862 GB] 1859 GB allocated
My latest problem is the error I'm getting when adding the fourth disk:
The disk attached to channel 4 could not be initialized. The most common reasons are RAID resync in progress, faulty drives, and disks that are too small to be added to the array.
[Mon Feb 14 19:46:59 EST 2011]
I have tried reboot a few times, I have also tried to init/format disk under XP - no problems. Still will not work under NV+ with the error as above.
Also I am not sure if I need to do anything about LCC
DISK1
Raw Read Error Rate 0
Spin Up Time 1000
Start Stop Count 16
Reallocated Sector Count 0
Seek Error Rate 0
Power On Hours 109
Spin Retry Count 0
Calibration Retry Count 0
Power Cycle Count 14
Power-Off Retract Count 13
Load Cycle Count 3051
Temperature Celsius 31
Reallocated Event Count 0
Current Pending Sector 0
Offline Uncorrectable 0
UDMA CRC Error Count 0
Multi Zone Error Rate 0
ATA Error Count 0
DISK2
Spin Up Time 9308
Start Stop Count 43
Seek Error Rate 0
Power On Hours 126
Spin Retry Count 0
Power Cycle Count 42
Power-Off Retract Count 41
Load Cycle Count 3667
Temperature Celsius 35
ATA Error Count 114
DISK1
Spin Up Time 966
Start Stop Count 15
Seek Error Rate 0
Power On Hours 94
Spin Retry Count 0
Power Cycle Count 13
Power-Off Retract Count 12
Load Cycle Count 2628
Temperature Celsius 33
ATA Error Count 0
Please advise ...
zest
DISK1
Spin Up Time 1000
Start Stop Count 16
Seek Error Rate 0
Power On Hours 109
Spin Retry Count 0
ATA Error Count 0
DISK2
Spin Up Time 9308
Start Stop Count 43
Seek Error Rate 0
Power On Hours 126
Spin Retry Count 0
ATA Error Count 114
DISK1
Spin Up Time 966
Start Stop Count 15
Seek Error Rate 0
Power On Hours 94
Spin Retry Count 0
ATA Error Count 0
Please advise ...
zest
Message 15 of 22
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-02-18
05:35 PM
2011-02-18
05:35 PM
After reading quite a few threads and not wanting to start another one, there's just 1 query someone needs to answer:
WD20EARS-00MVWB0 drives, NV+ NAS, 4.1.7 firmware...should end-users do ANYTHING on the TLER issue or not?
Message 16 of 22
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-02-18
05:40 PM
2011-02-18
05:40 PM
Shouldn't be a need to do anything regarding TLER if you're running 4.1.7 (or later once newer firmware is released) on a NV+.
See http://www.readynas.com/RAIDiator_4_1_7_Notes
The factory default on 4.1.7 is still needed to get the 4k sector alignment though.
yoh-dah wrote:
New features and enhancements
8. Added support for WD drives that don’t support TLER.
Message 17 of 22
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-02-19
03:32 AM
2011-02-19
03:32 AM
mdgm wrote: Shouldn't be a need to do anything regarding TLER if you're running 4.1.7 (or later once newer firmware is released) on a NV+.
Thanks mdgm, you're always one to help out here 🙂
The point #8 really didn't make much sense to me (and I'm sure others), it says it adds support for WD drives that DON'T support TLER...my English must be failing me since to me it means that it now supports those WD drives that don't have TLER?
Message 18 of 22
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-02-19
04:44 AM
2011-02-19
04:44 AM
WD has discontinued support for TLER on recent firmware revisions of some of their drives.
Message 19 of 22
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-02-19
11:05 AM
2011-02-19
11:05 AM
A very good thread that clarifies some points is here (Netgear, you really need to update your FAQ about WD EARS/EADS drives and their revisions!)
The LCC issue is somewhat alarming, especially given the stock values that WD ships its drives with.
Not at all something an end-user wants to hear!
I read somewhere that the WD20EARS is designed for around 1,000,000 LCC and at the rate of around 3000 per day thats 1000000/3000=333.3' Days for design life failure..
A guesstimation forcast of less than a year before harddrive failures.
Message 20 of 22
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-03-07
01:55 AM
2011-03-07
01:55 AM
TechZ wrote: A very good thread that clarifies some points is here (Netgear, you really need to update your FAQ about WD EARS/EADS drives and their revisions!)
A friend of mine just setup an identical NAS: WD20EARS-00MVWB0 x4 + an NV+, the LCC is at 9858 after 254 hours of operation.
Message 21 of 22
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-08-27
02:25 PM
2011-08-27
02:25 PM
Hi,
I own a readynas DUO on 4.1.7 and have opened a case with netgear support... but with the same drives I have one that jumps to an unrealistic 239°C. the device doesn't seem to be catching fire so that must be misread... which is a bit worying about how these drives are reliable.
I'll follow this thread 🙂
Message 22 of 22
