× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
WDC WD6002FRYZ-31WD5B0 bad or compatibility issue?
IT13
Follower
Hello,
I've installed a new hard drive Disk Model:WDC WD6002FRYZ-31WD5B0 to replace another one in my unit ReadyNAS 4220.
The hard drive is listed on ReadyNAS Hard Disk Compatibility List
This disk should be compatible based on the test result of another disk in the same series from the disk manufacturer.
https://kb.netgear.com/20641/ReadyNAS-Hard-Disk-Compatibility-List?cid=wmt_netgear_organic
I have exported the logs from the unit and can see as follows:
1) disk_info log:
Device:             sdf
Controller:         0
Channel:            1
Model:              WDC WD6002FRYZ-31WD5B0
Firmware:           01.01MS3
Class:              SATA
RPM:                7200
Sectors:            11721045168
Health data
  ATA Error Count:                0
  Reallocated Sectors:            0
  Reallocation Events:            0
  Spin Retry Count:               0
  Current Pending Sector Count:   0
  Uncorrectable Sector Count:     0
  Temperature:                    37
  Start/Stop Count:               2
  Power-On Hours:                 1
  Power Cycle Count:              2
  Load Cycle Count:               2
2) systemd-journal is full of
Mar 20 20:11:40 nasXXXXX kernel: ata2.00: status: { DRDY ERR }
Mar 20 20:11:40 nasXXXXX kernel: ata2.00: error: { ABRT }
Mar 20 20:11:40 nasXXXXX kernel: ata2.00: configured for UDMA/133
Mar 20 20:11:40 nasXXXXX kernel: ata2: EH complete
Mar 20 20:11:40 nasXXXXX kernel: ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
Mar 20 20:11:40 nasXXXXX kernel: ata2.00: irq_stat 0x40000001
Mar 20 20:11:40 nasXXXXX kernel: ata2.00: failed command: READ DMA EXT
Mar 20 20:11:40 nasXXXXX kernel: ata2.00: cmd 25/00:08:00:f4:a0/00:00:ba:02:00/e0 tag 15 dma 4096 in
                                           res 51/04:08:00:f4:a0/00:00:ba:02:00/40 Emask 0x1 (device error)
I'm almost sure the hard drive needs to be replaced again. But before I get a 2nd exactly the same one I would appreciate if someone could confirm that the particular model is really compatible.
Thank in advance!
Model: RN4220X|ReadyNAS 4220 10Gbase-T
Message 1 of 2
FramerV
NETGEAR Employee Retired
Re: WDC WD6002FRYZ-31WD5B0 bad or compatibility issue?
Hi IT13,
Before we conclude anything. May I request for the system logs first?
How do I send all logs to ReadyNAS Community moderators?
Please update the thread once sent so that I can ask assistance on checking the logs.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3080 views
  • 0 kudos
  • 2 in conversation
Announcements
