- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
What is the maximum size for an external USB hard drive for backing up the RNDP6310?
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the maximum size for an external USB hard drive...for backing up the ReadyNAS RNDP6310 by connecting to the front backup USB port?
Thank you
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@nowthennet wrote:
What is this SMR business? What does that mean?
SMR: shingled magnetic recording.
http://www.tomsitpro.com/articles/seagate-8tb-archive-hdd-review,2-822.html wrote:
SMR, in its simplest terms, is a method of overlaying data tracks, much like shingles on a roof, to increase data storage density. One of the greatest aspects of SMR technology is its low cost per gigabyte; the Seagate model we have under the microscope retails for 3 cents-per-GB. However, SMR comes with inherent performance constraints, and some implementations have limited compatibility with existing systems
Normal drives shipping today are "PMR" - perpendicular magnetic recording.
With SMR technology, the storage is increased by overlapping the data tracks on the disk. This is cost-effective (which is why these drives are cheaper than PMR 8 TB drives). The downside is that when you write to a track, the next track is trashed because of the overlap. In order to maintain data integrity, the drive has to "ripple" the write until it reaches an unused track (or the end of the drive).
For instance, if you write to track 100, the disk firmware actually needs to do this:
read 101, write 100
read 102, write 101,
read 103, write 102
The drive firmware does this in the background automatically with a large cache, but this will greatly slow down write speed if you are doing a lot of sustained writes. And there still been compatibility issues. The linux community has patched drivers, and Netgear made some of their own modifications to the OS 6 firmware.
None of these are available on your older Pro-6.
@nowthennet wrote:
Where can I find instructions for updating the BIOS and upgrading to 0S6?
Both are in this forum. OS6 isn't supported on the older NAS by Netgear, although they have fixed some bugs that are specific to older NAS anyway. The upgrade is destructive, so you will need to back up your data somewhere.
The bios upgrade is here: http://www.readynas.com/download/addons/x86/4.2/BIOS_Update_Package_0.5-x86.bin You install it like an add-on.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: What is the maximum size for an external USB hard drive for backing up the RNDP6310?
Hi nowthennet,
I believe the highest capacity it can support is 3TB or 4TB. Let's wait for other community members and see if they've tried other higher capacity external USB hard drives.
Kind regards,
BrianL
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
There should not be any limitation here, other than limitations set by the filesystem you use on the external USB.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I bought this drive:
SEAGATE Backup Plus External Hard Drive - 8 TB
It came fortmatted as NTFS. I left it as that because I have found that I cannot successfully backup to my smaller 750GB drives if they are formatted to ext3 or fat32. I don't know why that is.
Anyway, my backup currently works fine when I connect my 750GB drives to the front backup USB port. However, when I connect the new 8TB drive, although it shows up on the ReadyNAS Frontview as an 8TB drive it simply does not seem to perform properly. The data that I am backing up from the ReadyNAS is approx 350GB. It manages to back that up no problem on the 750GB USB drives (apart from some complaints about maintaining permissions and some file names and path names that are too long) but when I connect the 8TB drive it takes 24 hours to back up about 30GB of data (approx). It seems to have no prospect of completing the back up.
Is this because the hard drive is too big? What would people expect to happen if the hard drive were too big?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Which firmware are you running?
Also if you download the logs what is the date in bios_ver.log ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The Pro NTFS write speed is about 17 MB/sec with a traditional PMR USB drive. That should give about 1.4 TB/day overall.
The Backup Plus is an SMR drive, so sustained write speeds will be variable (and slower than the normal PMR drives). But you should still be seeing TB/day not GB/day.
Maybe while you are waiting for mgdm to look at the logs, you might try benchmarking the drive speed on a PC (preferrably using a USB 2.0 port). The drive has a large internal write cache, so you need to test with a lot of data (preferrably ~100 GB).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Firmware: Radiator 4.2.28
bios_ver.log: 10/03/2008 FLAME6-MB V1.6
- Mark as New
- Bookmark
- Subscribe
- Permalink
There is a newer bios available - but perhaps wait for mdgm to respond as to whether installing it is a useful step.
- Mark as New
- Bookmark
- Subscribe
- Permalink
There is a newer BIOS available for it: https://community.netgear.com/t5/Community-Add-ons/More-on-CPU-specs-of-the-ReadyNAS-Pro/m-p/635196#...
I doubt updating the BIOS would make any difference though.
Do you get similar performance with a smaller capacity USB disk?
- Mark as New
- Bookmark
- Subscribe
- Permalink
No, the smaller capacity disk works fine (but only if it is NTFS by the way). It is much faster and the backup completes after about 24 hours or so. With the larger 8TB disk the backup fails to complete.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am thinking it is likely an SMR issue. Can you try a sustained write test in a PC?
- Mark as New
- Bookmark
- Subscribe
- Permalink
If that is the case then updating the BIOS and then upgrading to OS6 (though running that on your unit is not supported) may make sense. OS6 does have some fixes to work better with drives that use SMR.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
read 101, write 100
read 103, write 102
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for taking the time for that lengthy reply.
How were you able to tell that it is an SMR drive?
So, this is all sounding like a bit of an awkward route. How about if I just purchase a different drive - a PMR one?
Could you perhaps suggest one that ought to work for me?
I would like to buy from either www.amazon.co.uk (not the Marketplace) or www.pcworld.co.uk
If it is going to make it more likely to work then I am prepared to go down to a 2TB drive, although 4TB would make it a lot more comfortable in terms of storage.
Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
PMR internal drives retail about $300 US and up at the moment (WD80EZRX and ST8000DM003); your backup-plus was quite a bit less (and quite close to Seagate internal SMR drives). Another possibility was that it had 2x4TB internally (which is what the WD my book duo does). Either way, it made me wonder so I googled it, and found this review: http://www.techradar.com/us/reviews/pc-mac/pc-components/storage/disk-drives-hdd-ssd/seagate-backup-...
It's a bit tricky to avoid SMR with seagate backup drives, because their datasheets are pretty sketchy. If you drop down to a 4 TB 3.5" drive you should be safe, since their smallest 3.5" internal SMR model is 5 TB. They do have a 4 TB 2.5" SMR though, so avoid the 4 TB backup plus portable. So maybe two of these: https://www.amazon.co.uk/Seagate-Backup-Desktop-External-Drive/dp/B00HSYI58U/ Total price is about the same as the 8 TB backup plus.
If you want the convenience of a single drive, then the western digital WDBFJK0080HBK is PMR, and is about £285 at amazon uk - more. https://www.amazon.co.uk/DRIVE-EXTERNAL-USB3-0-BPSCA-WDBFJK0080HBK-EESN/dp/B01E9QPEKG/
I'd avoid the cheaper Mybook 8 TB duos - they use 2 drives inside, and I don't think they will be as reliable.
Another option would be to get a USB 3.0 enclosure, and use that with an internal drive. Then you know what you are getting (since the internal drives always have pretty complete datasheets). That is usually more expensive though.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you
It does not need to be Seagate and I don't need 8TB. 4TB would be plenty. 2TB would be sufficient but 4TB would give me plenty of room.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sounds like you have a good path forward then.
BTW, SMR isn't a bad choice for backup drives, especially incremental backups. It is quite cost-effective. But your NAS pre-dates SMR, and doesn't have the driver patches needed to use them reliably.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you to everybody for your help. I will give a PMR disk a try. If that doesn't work....I'll be back.
