× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Won't run with 2 disks in
dunkymole
Hi,
ReadyNAS Ultra 2+
I recently woke up to no NAS on the network 😞
I did an OS reinstall and no joy. I then rebooted with first one disk out, then the other. The device seemed to work when disk 2 was no present so I bought another drive and inserted that. Same issue.
It looks like having any disk in bay 2 causes this: http://imgbin.org/index.php?page=image&id=17612
To add to all this, I have started getting fairly frequent emails with the following:
Unexpected enclosure status detected
V+12 power is out of normal range [expected: 12.00 current: 11.03].
The unit is still under warranty. Any ideas?
Message 1 of 5
Guru
Re: Won't run with 2 disks in
contact support.
Message 2 of 5
dunkymole
I actually kind of thought that was what I was doing. I thought theses boards were monitored. Tips on how to get them?
Message 3 of 5
Guru
support.netgear.com.
Use email if you purchased more than 90 days ago.
Message 4 of 5
dunkymole
Thanks
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 4475 views
  • 0 kudos
  • 2 in conversation
Announcements
