× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Reply
format disks..
Magmo
format disks..
Hi
I want to format/delete al files thats being stored on the ReadyNAS Ultra 4 Plus, from where in the admin interface can I do that?
Message 1 of 3
vandermerwe
Master
Re: format disks..
Go to raidiator.
Select System, update.
Select factory default.
Perhaps before you do this you could upgrade to the latest firmware (4.2.26).
This will wipe all your data and reset the device to factory settings - your network settings will be reset so you'll need a dhcp server on or you can reach the NAS through raidar.
You may also want to backup your configuration, then restore it after the reset. This is also in the system menu.
Back it up. Use UPS.
Infrant Readynas NV+ | Readynas Ultra 6 Plus | Readynas 316
Message 2 of 3
Magmo
Re: format disks..
Thanks that worked perfect!
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2940 views
  • 0 kudos
  • 2 in conversation
Announcements
