- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
legacy readynas Pro on OS6. How to Upgrade from 2TB to 8TB
- Mark as New
- Bookmark
- Subscribe
- Permalink
So I just upgraded to the OS6 firmware( Firmware 6.9.5 to be exact)
I have 2TB hard drive and want 8TB hard drive.
Can I just replease the entire array or do I have to replace 1 drive at a time?
There is NO DATA currently on the array so that is not a concern.
Thanks you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: legacy readynas Pro on OS6. How to Upgrade from 2TB to 8TB
In other words, I want to upgrade from 6 X 2TB hard drives to 6 X 8TB hard drives.
- Mark as New
- Bookmark
- Subscribe
- Permalink
if there is no data, then just power down, pull all the old drives, put all the new drives in, and power back up.
new system will be initiallized and raid 5/x-raid will start resyncing.
if you want raid 6/dual redundancy, then you must delete the default volume, create a new raid 6 volume, then re-enable x-raid (if desired).
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is the fastest and best approach. Replacing one drive at a time in the existing array will take a lot longer.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, I will do this.
Just as a side note, which drive/bay is #1? like the bottom left, top left, etc.l..
I am trying to find a layout diagram of which bay 1, bay 2, bay 3, bay 4, bay 5, bay 6.
I have always heard its a good idea to number each drive in case of a problem.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've never seen a diagram, it's an odd oversight.
Your NAS numbers the bays left to right, then top to bottom. (bay 1 upper left, bay 6 lower right).
It is a good idea, as it makes it much easier to keep them straight if you remove more than one. I put a label on each drive.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for your help. I went ahead and labeled them. If you ever have to take them out to check the drive for a problem or even for recovery, the correct drive number is very important I am told.
I was downloading the PDF manuals and paging in them, looking at google image search but could not find any diagram. Now I know why. It was becasue it did not exist. Maybe something to include for future model documentation?
Thanks again.
