× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
readynas nv+ dead, how to recover disks?
fooprobe
my trusty NV+ finallky quit.  not in the serial number range for the PSU service action.  i have a backup, but it's a hassle because the backup doesn't delete old folders when i move them around on the RAID, so there are a lot of old folders hanging out on the backup and i'd have to sort through manually to find the most recent ones.
any suggestions on recovering the disks?  is there a readynas i could migrate the disks to? i actually don't think i need a RAID anymore, kind of overkill for my use, but i don't know if there's any other way to recover the disks besides plugging them into a new chassis.
any thoughts?
-emil
Model: ReadyNASRND4000v2|ReadyNAS NV+ v2 Chassis only
Message 1 of 9
Marto731
Re: readynas nv+ dead, how to recover disks?
Emil,
    I take it power supply is dead. If you know someone with an active NV+, or search for a PSU.
    The later x86 and ARM units are not compatible with Sparc NV+.
      Regards, Marto
Message 2 of 9
fooprobe
i don't know for certain that the PSU is dead but it looks like it.  i get no lights at all, unresponsive.
i was afraid that's what you would say =(  ok, thanks for the feedback.
Message 3 of 9
Guru
If you have a suitable linux machine (with enough connections for the disks) you could do this: http://home.bott.ca/webserver/?p=306
Note you can use a linux boot CD with an ordinary PC.
Message 4 of 9
fooprobe
oh! interesting.  i might be able to make that happen actually.... thanks!!
Message 5 of 9
BrianL2
NETGEAR Employee Retired
Hi fooprobe,
Were you able to mount your disks on a Linux machine to get your files?
Kind regards,
BrianL
NETGEAR Community Team
Message 6 of 9
fooprobe
I haven't had a chance to try it yet.  I still need to get replacement storage up and running, and my personal life is in the way.  If i get it working i'll let you know about it....
Message 7 of 9
BrianL2
Hi fooprobe,
Alright then. Just keep us in the loop on what happens next.
Kind regards,
BrianL
Message 8 of 9
mdgm-ntgr
If you do get a new ReadyNAS there is a process for support to attempt to recover data using that. See http://kb.netgear.com/app/answers/detail/a_id/29875/~/readynas%3A-migrating-disks-from-raidiator-to-...
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 5638 views
  • 0 kudos
  • 5 in conversation
Announcements
