Orbi WiFi 7 RBE973
Reply
reestablishing SMB-Connections lasts up to 30 minutes
JovannB
Tutor
Hi,
I've a 314 NAS (mounted as drive M:\) behind a HP-Procurve-Switch, for some reasons (ransomwareprotection) I disconnect that certain switch port by snmp-command - thats no problem.
Later then I reestablish that connection - switching that certain switch-port on.
Then it lasts between 10 and 30 minutes, till I can access the NAS by drive-Letter which is M:\.
Interesting is, that after switching the Procurve-Switchport on, I can access that NAS Admin-Page immediatelly, but why not the drive M: which is connected via SMB to my Windows system.
Whats the reason for that behaviour and/or is there configuration to improve - shorten that time afer switching port on an ability to connect to M:\ - the situation ?
J.B.
Model: RN31443D|ReadyNAS 300 Series 4-Bay
Message 1 of 11
Accepted Solutions
JovannB
Tutor
Re: reestablishing SMB-Connections lasts up to 30 minutes
Hi,
I installed the latest Firmeware (6.7.4.) on my NAS some days ago and now I thought to test whether something has changed relating to my problem.
Indeed, when I disable my Switch-Port (where NAS is connected to) and then (re-) enable that Switch-Port (HP-Procurve-Switch, disabling/enabling via SNMP-Command) then it lasts 10 seconds!!!! until I have a SMB-Connection to my NAS.
Amazing, thank you for your effort spent in my case.
J.B.
Message 11 of 11
All Replies
mdgm-ntgr
NETGEAR Employee Retired
Odd. Can you reproduce the issue then send in your logs (see the Sending Logs link in my sig)?
Message 2 of 11
JovannB
Tutor
Hi,
as far as I can see in the logs there is nothing in particular - I jotted the time down when I did my tests 10:32 and at that time there no log-entries
Is there a deeper inview into the logs ??
Where to upload or sent the logs too ??
J.B.
Message 3 of 11
mdgm-ntgr
The article linked to in my sig explains how to provide the logs.
Message 4 of 11
mdgm-ntgr
Perhaps try disabling local master browser functionality:
# echo "local master = no" > /etc/frontview/samba/smb.conf.overrides
Message 5 of 11
JovannB
Tutor
Hi,
I tried that (putty and then entered your commands) and checked by using cat on that file smb.conf.overrides. It was put in there.
But nothing changes.
Than I tried to reboot my NAS to put parameters in work - the same problem - reboot finished at 15:31 (could access via Putty and/or Web) but couldnt connect via UNC-Path or drive-letter which was still stored.
But then at 15:39 I could connect to UNC-Share, everything works fine.
Changed but the problem persists because I cant and dont wanna wait up to 10 minutes (in this case, who knows, how this time vary).
Message 6 of 11
JovannB
Tutor
Hi,
I'm still looking how to improve that situation - I want to enable my HP-Procurve-Switch-Port (e.g. Port 12), where my ReadNas is connected to, and then I want to access the Readynas SMB-Share.
Immediatelly after enabling the switch-port 12 I can access Readynas via Telnet, Web but not via SMB - therefore I've at least to wait 10 minutes.
How to decrease that time, I've to wait for SMB-Services ??  E.g. if thats 30 sec or 2 minutes ok, but not 10 or more minutes!
J.B.
Message 7 of 11
Guru
Are you just reconnecting the ethernet with the NAS running, or are you restarting the NAS?
Message 8 of 11
JovannB
Tutor
Hi,
I want to disconnect and reconnect my NAS by disabling/enabling my HP-Procurve-Switches Port by SNMP.
Till now, it was not my plan to reboot NAS after enabling my Procurve.
But as I learned to know, after a NAS reboot it lasts minutes (I would say 5 - 10 min) too till I can access the NAS via SMB (http and telnet access work instandly after a reboot), looks like as it is the same issue rebooting or switching that Procurve-Port on.
J.B
Message 9 of 11
JovannB
Tutor
Hi,
I've only one 314-NAs, can someone out there try if it is possible to replicate my problem ??
Delay of possibility to establish SMB-Connection after disconnection/reconnection of ethernet or after rebooting the NAS.
J.M.
Message 10 of 11
JovannB
Tutor
Hi,
J.B.
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 7925 views
  • 0 kudos
  • 3 in conversation
Announcements
