- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
upgrading using old disks NV+ to RN214
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi, thanks for advice on upgrading and retaining old disks, I have a readyNAS NV+, so well over 10 years old. It runs fine but is showing its age and this obsolete tech has issues, as you will know. I upgraded the disks a year or two ago to 4 x 2TB Seagate ST2000DM005-2CW102 which are 3.5 inch SATA NAS capable drives.
My question is, if I buy a diskless RN214, can I simply swap the disks across. The spec says it takes 3.5 SATA and runs X-RAID, but I am aware thats minimum info. Will changes in chipsets or OS or RAID technology prevent a straight swap? Obviously I can back up the data, install and reformat drives and start again, which might be better. As I am not NAS tech savvy, any advice appreciated. thanks, Eddy
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Welcome to the Community!
It is fine to use the old drives you have from the NV+ to your RN214 but the data needs to be backed up first since the drives will be reformatted once you migrate the drives to the RN214.
It is also possible to get the data accessible on the RN214 before formatting the drives but it will need intervention from Support. IMO, it would be best if you have a backup of your drive and start from scratch on the RN214 and transfer the data once setup is complete.
Straight migration is not possible since they have different OS.
HTH
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
HTH
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: upgrading using old disks NV+ to RN214
Many thanks for a nice clear answer, I will start again
Eddy
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@eddy291 wrote:I upgraded the disks a year or two ago to 4 x 2TB Seagate ST2000DM005-2CW102 which are 3.5 inch SATA NAS capable drives.
I don't know who sold you those as "NAS capable", but the DM series are desktop drives and are not recommended for use in RAID configurations such as a NAS. That sounds like a term sombody invented to fool you into thinking they are "NAS purposed", as are the Seagate Ironwolf (VN) series.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
thats also very helpful thanks, I was told these were suitable "for entry level NAS" as sold by my university supplier. As it isn't on all the time I didnt check any further, but in that case I will have to think about new drives too. Eddy
