× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Difference between RNDP6000-200EUS and RNDP6310-200
steveoelliott
Luminary
Hi,
I've heard that the RNDP6000-200EUS is EOL and been replaced by RNDP6310-200.
What's the difference? Is it still possible if using the newer model to swap the drives out of one and into the other in a failure scenario?
Cheers...
Message 1 of 6
mdgm-ntgr
NETGEAR Employee Retired
Re: Difference between RNDP6000-200EUS and RNDP6310-200
One is diskless and the other comes with disks installed.
You can migrate from one Pro 6 to another. First ensure (if possible) that the firmware version is the same on both units then follow this procedure: http://www.readynas.com/kb/faq/boot/how_do_i_migrate_disks_over_from_an_existing_readynas_to_another
Message 2 of 6
steveoelliott
Luminary
OK Thanks.
I was aware that there are multiple versions of the Pro 6 so providing the migration of disks between units is reliant on FW being the same and not affected by minor HW differences then that's not a problem.
It appears that diskless units are not available now, hence why I am purchasing an older version.
Message 3 of 6
Guru
The RNDP6310-200 is not older, and the RNDP6000-200 appears to be in stock at Amazon.
Message 4 of 6
steveoelliott
Luminary
Thanks...
Amazon sellers do have them but the RNDP6000-200 is not available in normal shops.
Message 5 of 6
Guru
steveoelliott wrote:
Thanks...
I think they can stock it if they wish.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2683 views
  • 0 kudos
  • 3 in conversation
Announcements
