× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Dum6a55 corrupted index.html readynas duo v2 sparc and need a copy from someone..
Simons101
Hi folks.
          Did something stupid and corrupted a file.
Index.html from root folder is corrupted and i need a replacement
So if any kind persons out there could upload this file i would be very gratefull.
Thanks in advance
Richard
Message 1 of 6
Accepted Solutions
Guru
Re: Dum6a55 corrupted index.html readynas duo v2 sparc and need a copy from someone..
I've attached what my NV+ v1 has in //frontview/ui/resource/html/index.html
Message 4 of 6
All Replies
Guru
The labeling on the NAS is a bit confusing, but from the forum's perspective there is no such thing as a duo v2 sparc.
Do you have a v1 system (sparc, 4.1.x firmware), or do you have a v2 (arm processor, 5.3.x firmware)?
Also, when you say "root" do you mean the root of the C data volume?  Perhaps give us the actual path you are seeing via ssh.
Message 2 of 6
Simons101
Hi StephenB,
Message 3 of 6
Guru
Message 4 of 6
Simons101
Hi StephanB
Thanks for the index.html sadly it didn't fix it must have messed up more than i thought
ssh ed in and used
touch /.os_update
and rebooted which fixed it,  think you also posted that fix
So thanks again, i owe you a pint.....
Message 5 of 6
Guru
I'm glad you're up and running.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1819 views
  • 2 kudos
  • 2 in conversation
Announcements
