- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
How to control fanspeed on a RN104 for 6.7.4
- Mark as New
- Bookmark
- Subscribe
- Permalink
Updating an old script to control the fan speed on the newer Firmware. I am not claiming credit all i did was update the sys path for the new frimware and change the startup script that had a typo
originally came from post https://community.netgear.com/t5/New-to-ReadyNAS/How-to-control-fanspeed-on-a-RN104/td-p/911970
1. First you create a file in /root with the name fanoverride.sh. Put the following lines in to the file.
nano /root/fanoverride.sh
#!/bin/bash ## Variables ## FANPWMPATH=/sys/devices/platform/soc/soc:internal-regs/d0011000.i2c/i2c-0/0-003e/hwmon/hwmon0/fan1_target FANSPEEDPATH=/sys/devices/platform/soc/soc:internal-regs/d0011000.i2c/i2c-0/0-003e/hwmon/hwmon0/fan1_input CORETEMPPATH=/sys/devices/virtual/thermal/thermal_zone0/temp MAXFAN=3500 # Maximum operable speed MINFAN=700 # Minimum operable speed MINTEMP=35000 #35 C MAXTEMP=70000 #70 C NEWSPEED=1000 # Initial fan speed (%) ## Functions ## function getReadings { FANPWM=$(cat $FANPWMPATH) FANSPEED=$(cat $FANSPEEDPATH) CORETEMP=$(cat $CORETEMPPATH) } function setFanSpeed { TEMPFAN=$(expr $MAXFAN - $MINFAN) NEWFAN=$(expr $TEMPFAN \* $NEWSPEED) NEWFAN=$(expr $NEWFAN / 100) NEWFAN=$(expr $NEWFAN + $MINFAN) if [ $NEWFAN -lt $MINFAN ]; then NEWFAN=$MINFAN fi if [ $NEWFAN -gt $MAXFAN ]; then NEWFAN=$MAXFAN fi echo New Speed: $NEWFAN RPM echo $NEWFAN > $FANPWMPATH } function calcFanPercent { TEMPRAN=$(expr $MAXTEMP - $MINTEMP) TEMPREL=$(expr $CORETEMP - $MINTEMP) TEMPREL=$(expr $TEMPREL \* 100) TEMPPER=$(expr $TEMPREL / $TEMPRAN) NEWSPEED=$TEMPPER echo New Speed Set: $NEWSPEED % at $(date +%T) } ################################################################### echo "Automatically controlling fan speed..." while true do getReadings echo "Temp: $CORETEMP C FAN: $NEWSPEED% [$FANSPEED RPM] [PWM $FANPWM]" calcFanPercent setFanSpeed sleep 5 done ###################################################################
2. Now chmod 755 /root/fanoverride.sh
3. Now create a file in /etc/init.d with the name fanoveride.
nano /etc/init.d/fanoverride
#!/bin/sh ### BEGIN INIT INFO # Provides: FanOveride # Required-Start: $local_fs $network $named $time $syslog # Required-Stop: $local_fs $network $named $time $syslog # Default-Start: 2 3 4 5 # Default-Stop: 0 1 6 # Description: FanOveride overides the default ReadyNAS fan control ### END INIT INFO SCRIPT=/root/fanoverride.sh RUNAS=root PIDFILE=/var/run/fanoveride.pid LOGFILE=/var/log/fanoveride.log start() { if [ -f /var/run/$PIDNAME ] && kill -0 $(cat /var/run/$PIDNAME); then echo 'Service already running' >&2 return 1 fi echo 'Starting service.' >&2 local CMD="$SCRIPT &> \"$LOGFILE\" & echo \$!" su -c "$CMD" $RUNAS > "$PIDFILE" echo 'Service started' >&2 } stop() { if [ ! -f "$PIDFILE" ] || ! kill -0 $(cat "$PIDFILE"); then echo 'Service not running' >&2 return 1 fi echo 'Stopping service.' >&2 kill -15 $(cat "$PIDFILE") && rm -f "$PIDFILE" echo 'Service stopped' >&2 } uninstall() { echo -n "Are you really sure you want to uninstall this service? That cannot be undone. [yes|No] " local SURE read SURE if [ "$SURE" = "yes" ]; then stop rm -f "$PIDFILE" echo "Notice: log file is not be removed: '$LOGFILE'" >&2 update-rc.d -f <NAME> remove rm -fv "$0" fi } case "$1" in start) start ;; stop) stop ;; uninstall) uninstall ;; restart) stop start ;; *) echo "Usage: $0 {start|stop|restart|uninstall}" esac
4. Now make sure it is executable
chmod +755 /etc/init.d/fanoverride
5. Make it start at boot or start it manually
#auto start with system update-rc.d fanoverride defaults #manually service fanoverride start service fanoverride stop
Use at you own risk and its not my fault if you break your NAS or burn your house down .
Post if you have questions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: How to control fanspeed on a RN104 for 6.7.4
Not sure why you'd want to use this with the range of in-built fan control options available now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well the build in method thur the GUI even on the cool setting doesn't seem to keep the NAS cool at all max i have seen 800-1000 RPMs. With CPU temp at 60 C. At least with this script you can get temps down to 50 C and HD temp will be lower as well.
I feel Netgear needs a better calc for fan speed or at least more control to the user. aka thermal limits based on temps like QNAP and almost every other vendor
Also i do feel like this script should only be used by people that really know what they are doing. Since it is basicly a hack job and will most likely break when 6.8 or later rolls out
- Mark as New
- Bookmark
- Subscribe
- Permalink
When my rn104 gets challenged its fan goes up to 3k+ rpm. That keeps the cpu below 60C and the 4 HGSTs in the 40s.
This is good enough for my purposes, because it is getting difficult to ignore the noise created by this level of cooling.
I never saw the fan going beyond 4k rpm and do not look forward to experiencing that. I imagine to hear such a level of noise, which could hardly be ignored in a living room.
I'm always using cooling option "balanced" and sometimes set that to "cool", if any kind of "purgatory" is in sight.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I live in Singapore and the auto fan control setting still don't keep the disks at acceptable temps, so this is useful. I don't want to wait until the disk hit 50+ degress for the fan to ramp up
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm getting 'Failed to start fanoverride.service: Unit fanoverride.service not found.'
any pointers?
- Mark as New
- Bookmark
- Subscribe
- Permalink
But, why don't install fancotrol from Debian repo?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Idk Never tried it on an ARM based system. I guess it would work if 104 uses a Lm-sensors to control the fan. My guess it might mess up the frontend gui. but idk
Have you used it? and if so any issues?
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can have right.
I don't test it - I have different model 😉
But fancontrol has tool for generation config and it can detect sensors on the motherboard.
- Mark as New
- Bookmark
- Subscribe
- Permalink
i'm willing to give this a go on my 314. just worried that it won't detect the sensors properly
