- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RN104 - Maximum Capacity
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I have an RN104 running the latest software.
Would there be a problem and an inability to give it 4 x 6Tb Hard Drives? Or even 8Tb Drives.
I want to increase the back up capacity but don't know if there are internal, built in limits that would prevent this.
Thanks
Albert
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Part of the point of mentioning 10TB disks is that if you do get 6TB/8TB disks there is still some potential there for future volume expansion.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RN104 - Maximum Capacity
@mar2251 wrote:
I have an R104 running the latest software.
There used to be a 16 TiB ceiling, but that was removed in OS 6.4.0. The system recognizes the drives properly (I've used WD60EFRX and WD80EFZX in my RN102, though that was JBOD, not RAID).
So an RN104 running 6.6.1 will work with 4x6TB or 4x8TB drives.
But the resync time goes up with capacity - it could easily take 4-5 days on an RN104 with drives this large. You might also want to avoid installing apps and turning off unnecessariy services, in order to maximize the memory available.
Also, you should research the drive mounting hole positions before you purchase. Some of the larger drives no longer have the center side slots - if that's the case, you need to remove the plastic inserts in the drive tray, and use screws to attach the drives using the bottom slots.
Some drives also are using "alternative mount positions" on the bottom, so some of the holes in the tray bottom might not line up. Netgear added new holes in the tray bottom last fall to accomodate the alternative mount positions..
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RN10400 - Maximum Capacity
Hi,
I'm a little confused.
As previousloy mentioned I have an R10400 running the latest software.
I am not doing a RAID but simply JBOD Saving - 4 Drives on my Desktop Computer direct to 4 Drives on the NASS.
What i'm trying to determine is if there is a problem with inserting 4 x 6Tb Hard Drives? Or even 8Tb Drives. These would then individually backup the 4 drives that are on my Desktop Computer.
So I want to increase the back up capacity of the NASS but dont know if there are NASS internal built in limits that would prevent this.
Thanks
Albert
- Mark as New
- Bookmark
- Subscribe
- Permalink
There are some 10TB disks on the compatibility list. Note that with some disks you may need to remove the tool less insert for the drive tray.
There is a performance impact from using higher capacity disks, but you can use them.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What in my answer confused you?
As I said, I've used WD60EFRX (6 TB) and WD80EFZX (8 TB) in my RN10200 using JBOD. The only difference between the RN102 and your RN104 is that the RN102 only has two drive bays.
RAID performance (resync, etc) shouldn't an issue with JBOD. But I'd still recommend care in enabling services and apps. The RN104 has less memory and a slower CPU than the other OS 6 NAS.
As both mdgm and I noted you might need to remove the plastic inserts in the drive trays and use screws instead - depending on what model drives you purchase. You also might find that some of the mounting holes on the bottom of the drive don't align with the screw holes in the bottom of the tray.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I really don’t want to get 10Tbs only 6 or 8’s are these equally usable and compatible?
Albert
- Mark as New
- Bookmark
- Subscribe
- Permalink
Third try: Yes, with the considerations noted above.
The hard drive compatibility list is here: https://kb.netgear.com/20641/ReadyNAS-Hard-Disk-Compatibility-List
Both the WD60EFRX and the WD80EFZX work well. If you go with Seagate, the best options are the Ironwolf ST6000VN and ST8000VN models (digits after the VN don't matter). With the Seagates you will have to remove the tooless plastic inserts in the drive tray.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can the Nass memory be upgraded?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@mar2251 wrote:
Can the Nas memory be upgraded?
No, it's soldered into the system board.
@mar2251 wrote:
Trying to get the answer from Netgear is like pulling teeth.
The forum is often faster. Note that some of the folks here are from Netgear (including @mdgm-ntgr)
- Mark as New
- Bookmark
- Subscribe
- Permalink
@StephenB wrote:
The hard drive compatibility list is here: https://community.netgear.com/t5/forums/replypage/board-id/readynas-general/message-id/13695
I think you may have grabbed the wrong URL. 🙂
I did find the compat. list here, though: https://kb.netgear.com/20641/ReadyNAS-Hard-Disk-Compatibility-List
- Mark as New
- Bookmark
- Subscribe
- Permalink
Looks like a cut/paste error on my part. I've edited my original post, just in case someone else clicks there.
I'm glad you found it on your own.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
Do you know if it's possible to increase the internal memory on the Nass in order to make it quicker?
if so, What would be required.
Albert
- Mark as New
- Bookmark
- Subscribe
- Permalink
The memory is soldered to the system board, so it is not upgradable.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Albert
Dear Albert.
Trully, I admire your inquisitiveness.
*You are perfectly right TO NOT believe in all those precise and comprehensive responses of most competent people on this forum.
** IT IS POSSIBLE to increase internal memory of your NAS
You would need ONLY:
- about 10y of technical studies in electronic/electric/software faculties
- team about 10-15 persons
- about few months work with this team
- some other minor things like i.e. money (about 150K $$$)
.. and then you would be able to design your OWN mainboard with suitable for you, amount of memory - and install it into your NAS.
Simply isnt it?
...till then i recommend for you the RTFM policy with combination of Reading with Understading
* possibly i would be banned for this 😜
** sarcasm
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Mr_Fr33z wrote:
* possibly i would be banned for this ;P** sarcasm
Personal attacks are out of bounds, criticism of Netgear is generally allowed.
FWIW, we often do get questions on upgrades here (CPU and memory). The ARM models can't be upgraded, but it is possible to upgrade memory on the others. Warranty is voided, and some units (particularly v1 ReadyNAS) are very fussy about the memory.
